Need 4K storage suggestions Windows users
Kenneth Maultsby
on Aug 25, 2019 at 11:23:57 pm
I am about to start my first 4K project and one of my hard drive crash on raid 0 system. I was able to get older projects off of it "lucky" Media was backup anyway. So I began Transcode my 4K footage from my Drobo to my 500GB SSD media drive DNXHR SQ and the driver wasn't big enough. I have order a 1TB SSD but if change my RockStor to a Raid 5 will it be fast enough for 4K? I would like to here from others here or suggestions what you use as a media drive for 4K DNXHR.
OS Windows 10
CPU AMD Ryzen 7 1700X 3.70 GHz
Memory 32 gb
Hard drives
C: SSD OS and Programs
E: Media SSD 500GB
F: 2 TB Documents and other programs
G: Drobo 6TB photos and videos
H: SSD 500 gb Cache drive
I: RockStor Raid 0 1x4 TB (Crashed)
OS Windows 10
Memory 32 gb
Hard drives
Pat Horridge
Re: Need 4K storage suggestions Windows users
on Aug 26, 2019 at 8:22:50 am
You need to do the maths.
What's the sustained data rate of your Raid 5 proposed setup (best to configure it and test. Or check manufacturers stated spec)
What's the data rate of you media.
How many real time streams will you need (at least 2 but possibly more if you are doing effects)
Add 20% or so overhead.
I'd not use Raid 5 Raid 1 or 10
Pat Horridge
Broadcast & Post Consultant, Trainer, Avid Certified Instructor
Free online Tutorials at VET digital media academy online http://vimeo.com/channels/752951
pat@vet.co.uk
Kenneth Maultsby
on Aug 27, 2019 at 8:44:43 am
What are using?
OS Windows 10 CPU AMD Ryzen 7 1700X 3.70 GHz
Memory 32 gb
Hard drives C: SSD OS and Programs
