Setting an individual audio track to always center pan
ben jones
on Mar 10, 2019 at 2:30:50 am
Hello cow people!
Im wondering if there is a way to set a specific audio track to always center pan when a clip is added to it. I know you can globally set all clips on a track to center pan but that is after the fact. I was thinking there might be an RTAS that can be applied. I also understand you could globally pan all the clips in the sequence you are cutting from, and you could also modify input settings, but without getting into too much detail, i only want to correct the pan as needed during rough cuts without modifying the source. Any help would be wonderful!
Thank you hive
