Color Code
Eric Santiago
Color Code
on Mar 3, 2019 at 9:42:10 pm
Is there another way of discerning clips in the sequence?
I would like the transcoded clips to appear differently than the RAW AMA clips.
Its a Sunday I know ;)
John Pale
Re: Color Code
on Mar 4, 2019 at 1:36:54 am
Yes. Hamburger menu at the bottom left of the timeline. Select Clip Color. Assign a color to Linked clips. If you are on an older version, it may say AMA. Then check Timeline Local.
Eric Santiago
Re: Color Code
on Mar 4, 2019 at 6:23:59 pm
[John Pale] "Yes. Hamburger menu at the bottom left of the timeline. "
What the? Was this always there?
I guess the move from 8.4 to 2018.xx I didn't check notes :)
John Pale
Re: Color Code
on Mar 4, 2019 at 7:26:31 pm
This has been there for a long time. Probably more options now than there used to be, but its an old feature. I’ve definitely used the Red Offline Media indicator for more than a decade.
