Avid - Recreate boomerang effect
Jessica Mutascio
on Feb 20, 2019 at 6:23:20 pm
Hi everyone,
Wondering if someone could offer me some insight into recreating a "boomerang" effect in Avid. I've been taking an action (whether it be .5sec, 1sec, etc.) and putting a timewarp on the clip to go from 100%-300%. Then I'm taking the exact same clip (starting at the same TC as the forward-moving clip ended on) and doing the reverse; however, it doesn't seem to be perfectly duplicating the frames. The last frame on the reversed clip does not match the start frame on the forward-moving clip, and I'm typing in the exact same values and using the default curve.
Is there a way to achieve this look and getting the exact same frames to go forward / reverse at the same exact same speed?
John Cuevas
Re: Avid - Recreate boomerang effect
on Feb 26, 2019 at 4:12:16 pm
You could create your time warped clip, do a video mixdown of it - then reverse the mixdown.
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
