my segment tool select several clips at a time
peter brelan
on Feb 10, 2019 at 6:04:52 pm
when I select a clip in my timeline, the clip below get selected as well.
in the picture we can see that I try to select only the clip on V1 A1 A2, but the clip on A3 A4 get selected as well. and this problem happens with other clips in the timeline. I just want to select the clip I dragged but the tool select other clips.
I hope you have a selection because i couldn't find one.
Thank you
Pierre
peter brelan
Re: my segment tool select several clips at a time
on Feb 10, 2019 at 6:07:03 pm
PS: if after selecting the clip's' i deselect the track A3 A4 the clips get deselected, but that process is very long.
John Pale
on Feb 11, 2019 at 2:59:00 am
You have Linked Selection turned on. The button under the word "timeline" at the top of your timeline toggles it on and off.
peter brelan
on Feb 11, 2019 at 9:31:56 am
great, thank you.
but actually when I turn off this icon, when i select the video I get just the video and no the audio.
It's a bit hard to explain, so i try again ☺
I drop a clip e.g. TRUCK FOOTAGE1 in the timeline, this clip has a video and two audio. I drop another part of this video TRUCK FOOTAGE1 in the timeline. When I stretch the audio of the second clip I dropped under the first one, and then Media composer consider them as linked ?
They are from the same source but they are two different clips, so why MC considers them as linked?
Thank you again
Pierre
John Pale
on Feb 11, 2019 at 1:40:23 pm
The linked media function will link together anything from the same master clip.
Honestly, I never use this function. Been using Avid since long before it existed, so I don’t miss it. Always seemed completely unecessary. I can see why people might want to use it, coming from other NLEs, though.
peter brelan
on Feb 11, 2019 at 4:11:28 pm
it's useful when i click on the video of the clip to select its audio as well without selecting the other audios.
anyway, i will do it like you mentioned.
Thank you
Pierre
