Replace clip w/o affecting Symphony Color Correction
Michael Buday
on Aug 27, 2018 at 9:51:15 pm
Is there a way to replace a clip on the timeline without removing Symphony color correction applied to it? I know with nested/effects I can drill down and replace the underlying native clip w/o removing the effects, but Symphony CC works differently - or am I wrong?
Right now I'm saving the correction in a memory slot, replacing the clip, then recalling the memory, but this is a lot of work.
MB
Shane Ross
Re: Replace clip w/o affecting Symphony Color Correction
on Aug 29, 2018 at 6:39:25 am
Sorry for replying late, I forgot to check this when I got in front of my system. I just checked, and no, you can't step into the color corrections on a Symphony...alas.
Shane
Little Frog Post
Glenn Sakatch
on Aug 29, 2018 at 6:44:08 pm
can you put the new clip on a new track, and copy the effect from bottom to top track?
Glenn
Shane Ross
on Aug 29, 2018 at 9:34:49 pm
Yes, that you can do
Shane
Little Frog Post
