Import MXF into avid
Lena Gregorian
on May 17, 2018 at 1:25:26 pm
Hello all,
I need to work with MXF files with avid 2018
I placed the MXF under Avid Media Files / 1/ ... (where the media is)
got an error "file is not AP-ATOM"
fair enough the MXF must be OP1-A
I drag the file into avid (Import): and get exception MPEG mapper segment
I try link to AMA: it says "failed to convert display to disk order
WHY SO HARD? WHY?
Michael Phillips
Re: Import MXF into avid
on May 17, 2018 at 4:18:47 pm
You can't import OP1a, you can only link to it via AMA. Or option-drag them into a bin should default to the MXF AMA plug-in. WOuld be a nice feature that if dragged for import that MC prompt for you try a link rather than fail.
Michael
