Bin's default to open in non- chronological order
Andrew Cross
on Feb 28, 2018 at 12:10:25 pm
Hi all,
Sorry if this is a lame question. I'm just transferring from 8 years of fcp/premiere.
When I'm opening bins they default to open in the wrong chronological order so each time I have to move the mouse over and double click the name to sort by name ( Clips are named chronologically).
It has only started doing this recently so I must have activated something by accident but can't for the life of me find out what it is.
Any help much appreciated!
Glenn Sakatch
Re: Bin's default to open in non- chronological order
on Mar 1, 2018 at 3:10:42 pm
I honestly don't know if there is a setting for that...I think it just saves the last state of the bin when you close it.
If you right click on the name column, and sort by ascending, then close the bin, what happens when you re open the bin?
I always use the sort by ascending option...not sure if it makes a difference or not.
Glenn
