Batch import not all audio tracks ie A1-3 just A1 gets imported
Ricky Milling
on Feb 27, 2018 at 1:09:59 am
Recently downgraded to 8.4.5 as i need it for another project. However, another one currently working on, everything is linked fine apart from audio for a pick up day.
Here the audio seems to be offline apart from A1 (of three tracks).
https://imgur.com/a/rgo8X
Above shows before and after, as you can see for some the tracks are ok, but for others two fo the 3 tracks do not import.
If i reimport from scratch all of the tracks are imported however this means i will have to re-sync a load of shots.
Any ideas why this is happening?
Pat Horridge
Re: Batch import not all audio tracks ie A1-3 just A1 gets imported
on Feb 28, 2018 at 7:03:24 am
With batch import there is an option to override the initial import settings. It's an extra bit ton you select and then you can override the track selection.
Pat Horridge
Broadcast & Post Consultant, Trainer, Avid Certified Instructor
Free online Tutorials at VET digital media academy online http://vimeo.com/channels/752951
pat@vet.co.uk
