Checking if my machine will run Avid Media Composer
Matt Patrick
on Feb 24, 2018 at 8:28:14 pm
Hello!
I'll be working on a project in AVID on my own machine for the first time and wanted to confirm that my machine will run AVID smoothly. We'll be working entirely in DNxHD36 for the offline--
My tech specs:
Model: iMac (21.5" inch / Late 2013
Processor: 2.7 GHz Intel Core i5 Processor with turbo boost to 3.2GHz
Memory: 16GB RAM DDR3
Graphics: Intel Iris Pro 5200
Won't be transcoding - primarily assembling dailies sequences and exporting from DNxHD36.
Thanks so much!
Matt
Shane Ross
Re: Checking if my machine will run Avid Media Composer
on Feb 24, 2018 at 9:10:30 pm
Yes, it'll do fine. Just make sure the OS version you are running is compatible with the version of Avid you'll be running.
Shane
Little Frog Post
