Import Media via Mac OS alias -- can it be made to work?
Ed Torr
on Nov 10, 2017 at 9:05:57 pm
When I try to import medai via a Mac OS alias Avid sees the alias a media to import rather than a pointer to the actual media. Is there a way to convince MC to look at the target file as opposed to the alias itself?
Trevor Asquerthian
Re: Import Media via Mac OS alias -- can it be made to work?
on Nov 11, 2017 at 11:00:47 am
Try symlink?
https://www.lifewire.com/aliases-symbolic-links-hard-links-mac-2260189
Trevor Asquerthian
on Nov 11, 2017 at 12:13:17 pm
OK you made me try it....
Alias - link maintained if original file is moved (symlinks lose link)
Symbolic link - does not maintain link if original moved, although if you replace original with same file name in same place then symlink will point to the new file
Hard link - prevents original being deleted, if original is moved then link is maintained
ALIAS:
AMA - no
Import - no
Batch Reimport once original moved - N/A
SYMLINK:
AMA - no
Import - yes
Batch Reimport once original moved - no
HARD LINK:
AMA - no
Import - yes
Batch Reimport once original moved - yes
SYMBOLIC LINK:
ln -s /path/to/originalfile /path/to/link
HARD LINK
ln /path/to/originalfile /path/to/link
Ed Torr
on Nov 12, 2017 at 2:44:41 pm
I'd been clued into the symlinks / hard link options thanks to a Avid Editors of Facebook response but I can't test until Monday. Thanks for all the AB testing!
What happens if instead of removing the original you remove the newly-created hard link? I would expect Avid to not to be able to find the original.
Ed Torr
on Nov 13, 2017 at 9:20:26 pm
So far N/G across the board, at least in our world here.
As best as I can tell Hard Links are not supported on ISIS
and Symlinks crashed the system
