Audio-only subclips (.WAV) not linking to master clip
Andrea DiNardo
on Nov 2, 2017 at 10:12:23 am
I've had to revisit a project that was copied onto a new drive and I have some audio-only subclips from a .wav interview. These clips are currently trying to link to the original drive. I've re-imported the master clip from the new drive, but I can't figure out how to relink these subclips, using the source finder or 'relink' feature doesn't work. Any help would be great!
Michael Phillips
Re: Audio-only subclips (.WAV) not linking to master clip
on Nov 2, 2017 at 12:19:20 pm
Find the master clip WAV files that these clips were subclipped from, select them, and do a batch reimport of the original WAV files. If you can't find the master clips, then do a "set bin display" and show reference clips and you will find them that way.
Michael
Andrea DiNardo
on Nov 2, 2017 at 2:11:26 pm
Hi Michael,
Thanks a lot - that did the trick!
Andrea DiNardo
on Nov 2, 2017 at 3:02:23 pm
Hi Michael,
I'm now having a slightly different issue with a music .wav file which is in the sequence, appearing offline. I've used batch re-import to import the original files, but they're still appearing offline in the sequence. Even when I 'Relink' the sequence to the two .wav files open in a bin it doesn't seem to work. Let me know if you have any idea of what this issue is!
Thanks again!
Andrea
Michael Phillips
on Nov 2, 2017 at 9:15:46 pm
If you do a match frame to the music event in the timeline, what does it bring up? You may have to overwrite with the newly updated clip as a last-ditch effort.
Michael
