NEW AVID MEDIA COMPOSER for new project?
Ross Spears
on Oct 13, 2017 at 3:20:05 am
First of all, thanks to all who have assisted me for years in putting together a very long form documentary with AVID Media Composer #4. I was told many years ago that MC 4.0 was perhaps the most stable version of MC that one could use. And use it I have -- for five years.
But now we are starting a new project -- another long form documentary -- and I want to have the best software available to deal with the newest formats and camera. What would the experts recommend? I have been editing in Avid for more than twenty years and I love it. What MC version, what computer, what hard drives need I acquire?
Thanks so much.
Ross Spears
Never Give Up
Shane Ross
Re: NEW AVID MEDIA COMPOSER for new project?
on Oct 13, 2017 at 10:10:15 pm
Are you more comfortable with a Mac or a PC? VERY long form? How much footage? Shot with what camera? Willing to do offline/online workflow, or want to work full resolution?
Shane
Little Frog Post
Ross Spears
on Oct 15, 2017 at 4:05:55 pm
Thanks Shane! Here are my answers:
I almost always work with Macs, including my AVID work. For me LONG FORM means feature length or short series -- i.e. from 2 to 4 hours in all. I will be shooting and also gathering footage from several sources -- probably will have 100-200 hours to work with in all by the end.
As for cameras, I just purchased a SONY pro CamCorder for $2000 that is capable of shooting 4K. It records onto San Disk cards -- the largest and best possible kinds. I like the Sony camcorder because its so small that I can still carry it around, it shoots in low light, and has a lot of focal length too. So far I have loved the footage, but I can't digitize it until I get the right editing setup. I am hoping that you can tell what to do??!!
I still have my Sony EX1, which I used to shoot a lot of the previous films -- a 3-film series called The Truth About Trees. You can see some of the footage on the website and YOuTube channel called TruthAboutTrees TV (or just TREE TV).
Thanks for your help1
Ross
Director, AGEE FILMS
Never Give Up
Shane Ross
on Oct 15, 2017 at 6:06:20 pm
[Ross Spears] "As for cameras, I just purchased a SONY pro CamCorder for $2000 that is capable of shooting 4K. It records onto San Disk cards "
What model? What format does it shoot? Specifics are needed for proper advice.
[Ross Spears] "probably will have 100-200 hours to work with in all by the end. "
And 4K? And you want to cut full/high resolution? 200 hours of UHD 2398 DNxHR SQ is about 42TB of footage. So I suggest getting a 64TB drive, something that G-TECH does offer. (you will need space to render, as well as 15-20% empty for optimal performance).
Computer...top of the line iMac will work for this, and is fine for 4K and not too expensive. Or you can get the MacPro Trashcan...more expensive as it has better processors, but it all depends on your budget. And Go with Avid MC 8.8.x. 8.9 is pretty new but 8.8.x seems solid.
Shane
Little Frog Post
Ross Spears
on Oct 16, 2017 at 12:00:40 am
Shane, as for the camera, i just bought the Sony Pxw-X70 Professional Xdcam Compact Camcorder. Does that help with more info? As for the format, what do you suggest?
Thanks for all this info. It helps a lot!!
ROSS
Never Give Up
Shane Ross
on Oct 16, 2017 at 5:20:38 pm
That camera shoots an XAVC format that might be tricky to bring in. XAVC-S I know is tricky on earlier versions, and you needed to buy a third party plugin for it as Sony no longer give a hoot about doing it. BUT...with Avid 8.9 it now has a built in AMA plugin for it...
SO transcode all your footage to DNxHR SQ, get an iMac or MacPro (whatever you can afford) and a 64TB RAID from OWC or G-TECH.
Shane
Little Frog Post
Ross Spears
on Oct 17, 2017 at 3:42:10 am
Shane! Thanks for the insights, information, and suggestions! I am very much obliged to you for keeping me in the "filmmaking" ballgame. It's all I can do to keep up with my content/subject matter on these films. Without your help I would be truly at sea in managing the technical sides too!
Many thanks, Ross
Never Give Up
Ross Spears
on Oct 18, 2017 at 2:19:21 am
Shane, Here is the computer I propose to purchase:
Apple 27" iMac with Retina 5K Display (Mid 2017), CPU: 4.2 GHz Intel Core i7 Quad-Core, RAM | Storage: 8GB RAM | 3TB Fusion Drive, GPU: AMD Radeon Pro 580 (8GB)
Is this what you are suggesting?
Thanks, Ross
Never Give Up
Shane Ross
on Oct 18, 2017 at 5:28:38 am
More RAM...at least 16GB. But yes, that will do fine. Now you need the external storage to hold all that media.
Shane
Little Frog Post
Ross Spears
on Oct 15, 2017 at 4:07:34 pm
P.S. I would like to work with full resolution if I can!
Never Give Up
Ross Spears
on Oct 18, 2017 at 3:22:13 am
Is this the type of computer you are suggesting?
Thanks, Ross
Never Give Up
Bob Zelin
on Oct 21, 2017 at 7:09:12 pm
Ross -
Shane told you in the previous post - YOU NEED MORE RAM ? Get it - minimum of 16 gig of RAM !!!
you are all excited about the computer to run Media Composer on. There are two things to remember -
you don't want to edit with native XAVC - you need to transcode this. Do you know how to do this ?
Do you know what AMA is ?
And you must address your storage. Have you looked at the prices of thunderbolt 2 or thunderbolt 3 RAID arrays that are at least 64 Terabytes ?
Bob Zelin
Bob Zelin
Rescue 1, Inc.
bobzelin@icloud.com
Ross Spears
on Oct 31, 2017 at 10:55:35 am
Thanks for the help! Here is a computer I am thinking of getting for the next journey. Will it work with MC 8.8? With the proper storage, will it do a longterm job?
iMac 5K Retina 27" Quad-i7
4.2GHz |Thunderbolt 3
32GB Ram | 2.0T Fusion | 8GB 580 Vid *Brand New w/Kb,Ms,AplCare+ to 2020
Thanks for your ideas!!!
Ross
Never Give Up
Ross Spears
on Nov 7, 2017 at 3:33:40 am
Hi Bob,
Thanks for your suggestions! Yes, I know how to transcode. Yes, I know what AMA is. and Yes, I have looked into and can afford to buy the enormous hard drives that you and Shane suggest.
But what I am wondering is if the RAM in the computer can be upgraded. If I buy a computer with 8 gigs, can I upgrade to 64 gigs?
Ross Spears
Never Give Up
Shane Ross
on Nov 7, 2017 at 5:53:25 am
[Ross Spears] " If I buy a computer with 8 gigs, can I upgrade to 64 gigs? "
You can, but that's more than you need if you ONLY run Avid. You can get 16 and you'll be fine. Beyond that you won't see any speed benefit at all. Avid doesn't leverage RAM...this just means you have have more than one app open at a time.
OR...if you use Adobe products, RAM does come into play
Shane
Little Frog Post
