Is AVID's YCrCb 709 color space the same as Rec 709?
Sherry Daniel
on Oct 10, 2017 at 11:54:50 pm
We're editing in the YCrCb 709 color space. Is this the same as REC 709?
We've been asked to specify the color space for accurate DCP creation and YCrCB is not on the list. We need help translating AVID's default color setting for the outside world.
We're using AVID MC 8.8.4. Project is HD 1080P. Workflow is video mixdown to ProRes 422 HQ MXF, then export "same as source".
Options for acceptable color spaces are:
sRGB
Rec709 2.2 gamma
Rec709 2.35 gamma
Rec709 2.4 gamma
P3 DCI
P3 D65
sRGB is obviously incorrect. Guessing Rec709 is the right translation but am unclear about which gamma setting is default for AVID YCrCb 709.
Appreciate any insights, thanks.
Job ter Burg
Re: Is AVID's YCrCb 709 color space the same as Rec 709?
on Oct 21, 2017 at 10:25:36 am
That's not so much a question of an Avid spec, but a monitoring spec. So did you color grade using a monitor calibrated to a 2.2 or a 2.4 gamma?
To the best of my knowledge, it is all a bit of a grey area, where fully controlled high end grading rooms tend to be set up with a 2.4 gamma, whereas 2.2 makes more sense in less ideal circumstances.
http://www.root6.com/support-2/tips/whats-the-best-setting-for-gamma-with-r...
Rich Harrison
on Nov 9, 2017 at 5:15:52 pm
You should most probably be using Rec709 2.4 gamma.
Rich Harrison
IT & Technical Coordinator
Airbud Entertainment Inc
