apple compressor
John Thomason
apple compressor
on Oct 4, 2017 at 6:35:50 am
I need to compressor my MC timeline to H.264 I already have compresses on my Imac .has anyone used this on MC. I know Squeeze is available but I don't want to pay for it if I don't have to. What is your work flow if you are using compressor
Michael Phillips
Re: apple compressor
on Oct 4, 2017 at 12:16:22 pm
Should be the pretty close to the same workflow - export a QT reference, QT Same as Source, or MXFOP1a and open in Compressor with your desired output settings and export. I use Adobe Media Encoder rather than Squeeze since I already have that and the process would be similar.
My reasons for using MXF OP1a are in my blog: http://24p.com/wordpress/?p=278
Michael
Brent Marginet
on Oct 5, 2017 at 3:26:22 am
You could always export an H.264 directly out of Avid.
If you want to use Compressor then export a ProRes or DNxHD QuickTime out of Avid and then run it through Compressor.
"MY MEDIA/PROJECT MOTO: If you think three copies of your media or project are enough.
Take a moment to place a value on them and then maybe add two more.
Hard Drives are now stupidly cheap. A RE-SHOOT AND YOUR TIME AREN'T."
