Are slashes "/" in archival date column OK?
Timothy Ballard
on Jun 28, 2017 at 12:19:43 pm
Hello,
Simple question: I'm entering data for archival material in Avid and I don't seem to have any issues so far, but just double-checking that as I enter dates for archival clips in a custom column with this format - year/month/day (ex: 1945/02/21 ) - that there will be no issues later on with the slashes.
I usually avoid anything other than _ for punctuation in Avid, but I think in this case it is easier to enter and read with the slashes.
In addition, some of the data contains " #'s" in another column for original file name. Will these be an issue?
Eric Santiago
Re: Are slashes "/" in archival date column OK?
on Jun 28, 2017 at 1:00:25 pm
I would avoid using that character or any odd characters.
Michael Phillips
on Jun 28, 2017 at 1:04:21 pm
You should be "OK" as long as it is metadata that is transmitted via ALE, AAF, etc, and is not a field that would be used as a filename at the OS level anywhere in the process like export, etc.
Michael
Mike Harper
on Jun 29, 2017 at 2:21:08 am
I would avoid you may have issues with other apps down the road. The_ should be be safe.
Mike Harper
http://www.editscore.com/
http://editscore.sourceaudio.com
