Adding LUTs in Avid and Working w/ DNx175 Footage?
Paul Frank
on Jun 25, 2017 at 6:53:35 am
Will adding LUTs to your footage in Avid slow the system down or eat up any processing power? Are there any cons to this workflow?
Will working in DNx175 on a feature with lots of footage slow Avid down? In the timeline there will be a widescreen matte layer and working with lots of group clips with 2 cameras. However, I will not be using multicamera mode.
I am used to working with DNx36 footage with the LUT already baked into the transcodes from Resolve and just wondering what Avid is capable of these days. We will be using a 2015 iMac with a single 8TB 7200rpm USB 3 gtech drive and a trashcan with a 4 bay OWC thunderbolt array with Raid 0 and 7200rpm Sata III drives. Will both or either of these systems work? Thanks for your help!
Glenn Sakatch
Re: Adding LUTs in Avid and Working w/ DNx175 Footage?
on Jun 25, 2017 at 4:32:57 pm
your widescreen matte may be the biggest barrier for smooth playback..depending on the length of your sequence.
Is it an actually matte key, or are you just using a film mask effect? I think a film mask should be much easier on the system.
Any DNX format on a decent box in Avid should run pretty smoothly.
Glenn
Paul Frank
on Jun 25, 2017 at 6:41:59 pm
I'm using the 1.66 film mask on the top video layer. The first cut could be as long as 3 hours but will eventually be closer to 90 minutes. I can break the film up into reels if need be. We could also bake the mask into the transcode if necessary.
Michael Phillips
on Jun 25, 2017 at 11:36:39 pm
Everything takes up some processing, so yes. How much? Hard to tell. Also, you might want to consider using the matte generator that's available in the source, record, and full-screen playback so you don't need to manage it as a top layer.
Michael
Paul Frank
on Jun 25, 2017 at 11:55:46 pm
How do you do the matte generator? Thanks!
Michael Phillips
on Jun 26, 2017 at 1:07:48 am
Project Window to select aspect ratio in "Mask Margins":
And then right click in the source or record viewer to choose Target Mask:
Michael
Paul Frank
on Jun 26, 2017 at 7:35:42 am
This is awesome and works great but the only catch is my exports don't have the mask with this setting. Is there a way to change that or do I have to put a mask in the timeline for it to work on exports? Thanks!
Michael Phillips
on Jun 26, 2017 at 1:59:22 pm
Check this setting in Export Settings:
Michael
Nina Lucia
on Jul 15, 2017 at 9:01:19 am
Is there anywhere to enable the mask exporting in 8.3.1? I can enable the mask but I don't have that export option. Seeing as you have the "legal range" option for the color space I assume you're on a later version.
If not, I can just make a mask but it seems there should be that option somewhere.
Interestingly, I just found in "Full Screen Playback" setting an option to enable the Target Mask for that but it doesn't affect exports. I'm glad to have found that though since I have burn-ins on the bottom of the screen in the matte that I want covered up when I play the cut in full screen for the director.
Michael Phillips
on Jul 15, 2017 at 10:54:49 am
The option to do so was added later so earlier versions of Target Mask did not have the capability.
Michael
