Importing Markers onto AVID Clips
Ryan Drum
on May 30, 2017 at 2:29:43 pm
Hi guys,
I have a question about markers and the way avid reads them. Is there a way of formatting a text file so that I can import the information as markers on a clip? I have a video hosting site that assigns a timecode to every comment in the comments section, and I am looking for a quick and easy way to assign these comments to markers in AVID.
Any insight would be very appreciated! Thanks!
Bouke Vahl
Re: Importing Markers onto AVID Clips
on May 30, 2017 at 2:34:20 pm
Sure, it's easy.
Export a marker list as .txt and study the file. It's not that hard.
Bouke
http://www.videotoolshed.com
Ryan Drum
on May 30, 2017 at 3:54:54 pm
I've got the importing markers working well on the record monitor - but I would like the assigning of markers to be to the clip, not necessarily a sequence. When I try to put the .txt file on the specific clip it says "the record monitor must be selected."
Michael Phillips
on May 30, 2017 at 8:08:48 pm
There is no ability to import markers on source clips via a text file (ALE). It can be done via an AAF.
Michael
Bouke Vahl
on May 31, 2017 at 1:52:17 pm
Sure you can, with a few extra steps.
Autosequence the clips you want the markers on, import markers on that sequence, copy/paste markers into the source.
(I assume the markers have to be set on V1.)
Instead of autosequence, any sequence with start / end overlapping the source will do.
hth,
Bouke
Ludmil Kazakov
on Jun 2, 2017 at 6:32:03 pm
I am having the same issue.. markers are currently on the timeline.. so when i frame match there are no markers.. and i need them on the source clip.. how do i do that? i tried export XML but when I have the clip opened and I am in the markers window, i cant import markers "The Record monitor must be selected"
