exporting subtitles from Avid
Strat Theo
on May 25, 2017 at 12:56:16 am
hello dears!
I am in trouble again. I need to export subtitles from Avid 6.5.2, not for another program, just to give the archive to a client. So, I have to deliver a file with Avid Caption TXT, UTF-8, and TTF letters archive . Synchronized, and with the word "start" for the begining in order to be synch. I tryied the caption export method (through effect mode) and it doesn't work. Any other idea?
Thank you!
Str
Bouke Vahl
Re: exporting subtitles from Avid
on May 25, 2017 at 9:25:09 am
So, you have a bunch of SubCap effects?
That should work. If you go into the effect editor, you can export a .txt file (It will be UTF-16 le).
Make sure you set it to export txt, not stl.
Then, the conversion to other formats is easy. If you don't own subtitle software and don't plan to do lots of subs in the future, outsource it. (I do it for a couple of beers.)
hth,
Bouke
http://www.videotoolshed.com
Strat Theo
on May 25, 2017 at 11:26:05 am
Bouke, thank you for your answer, the problem is that avid does not export anything from the subtitles. I go to effect editor / subcap/ caption file/ export caption/ . Then I select avod DS caption file (*txt) , put file name etc./ save /AND nothing happens
Bouke Vahl
on May 25, 2017 at 12:23:17 pm
I have no clue...
Can you mail / WeTransfer me a bin with the sequence?
(And your project FPS...)
Bouke
Strat Theo
on May 25, 2017 at 12:37:14 pm
I am not sure if I know how to do this....i mean what exactly / how to should I export
Bouke Vahl
on May 25, 2017 at 12:45:33 pm
Create a new bin, named 'bouke', copy your sequence in that, quit avid.
Then, go to the project folder, zip the file called 'bouke.avb' and send it to me.
Bouke
Strat Theo
on May 25, 2017 at 5:19:32 pm
SENDED! I hope I did everything right
Strat Theo
on May 25, 2017 at 3:23:59 pm
Bouke Vahl
on May 25, 2017 at 7:58:13 pm
No, you did not,
To where did you send what?
Not to my e-mail, nor did you post a link where the file could be downloaded.
These are very basic things. If you cannot do this, do not expect any help.
Bouke
Strat Theo
on May 26, 2017 at 7:28:13 am
sorry to bother you, I send it as an attechement(file upload) here, on a responce mail, the same way I am sending you this messagge.
Strat Theo
on May 26, 2017 at 7:45:43 am
I will send it to your e-mail.
Thank you.
Bouke Vahl
on May 26, 2017 at 8:06:16 am
So, where is the file?
Bouke
Strat Theo
on May 26, 2017 at 9:38:18 am
I got this from your e mail
MAILER-DAEMON@yahoo.com
To:rezenta@yahoo.com
May 26 at 10:43 AM
Sorry, we were unable to deliver your message to the following address.
550: High probability of spam
--- Below this line is a copy of the message.....
do you have another e mail? or is there any other way to send it to you?
Bouke Vahl
on May 26, 2017 at 10:39:43 am
Sure, try this:
https://videotoolshed.wetransfer.com/
Bouke
Bouke Vahl
on May 26, 2017 at 12:49:12 pm
Ok, got your files, and it works fine on my system. (You should have a .txt file by now.)
So, 'something' is fishy with your Avid... (I have no clue what it is, either your version, or you need a clean install)
From the images I cannot tell you doing anything wrong, it just does not work on your system.
Few other points, your work is a bit messy, contains double spaces, extra empty lines, spelling mistakes.
You should consider cleaning it before sending it out.
Last but not least, for a feature with 900+ titles, you really should look at a dedicated subtitle app.
This is (after you've mastered it) way faster.
(My Subbits being one of them.) Shameless self promotion:
https://www.videotoolshed.com/product/subbits-subtitler/
Bouke
Bouke Vahl
on May 26, 2017 at 12:51:41 pm
Oh, in 'Box appearance', set it to 'as many rows as needed'.
Then you will get bottom aligned text. (So a single line appears at the bottom, looks better.)
hth,
Bouke
Strat Theo
on May 26, 2017 at 2:48:16 pm
Thank you for your interest Bouke, I 'll keep in mind your notifications, (that was my first editing -I'm a director, usually I just give orders to somebody).
Any way, the good news is that the problem is SOLVED. I am not sure how, but I will put here my guess for the next despaired director. Maybe, the fact that I opened (for the 10th time) the edit caption, and without changing a thing –Noting at all- I closed it again, using the ok command instead of cancel made it work.
As magic it's not my style, is the only explanation I can think.
Now , I'll have a look on your subtitling app!
Thanks a lot!
