Searching for keywords using the comments section
Veronica Pinkham
on May 15, 2017 at 8:31:09 pm
It seems that it is not possible to search for keywords I include in the comments column - true? Would the best workaround be to make markers with keywords? I haven't found a good thread discussing this. Thanks!
Glenn Sakatch
Re: Searching for keywords using the comments section
on May 15, 2017 at 11:16:09 pm
Did you try "control F"?
Just did a search for a word i put in a column called "help", and it called up the word in the column
Glenn
Veronica Pinkham
on May 16, 2017 at 12:07:45 am
Yes, it is working now. That's how I tried it before, didn't work. Tried it again, now works! I suspect maybe the first time I tried I simply hadn't saved/closed the bin, so it hadn't registered the change yet. Silly me. Thank you!
