Redundant Avid media
Scott Davis
on Apr 24, 2017 at 11:57:46 pm
I have an Avid MediaFiles folder that might contain a lot of duplicates (media was copied over at the Finder level). Is there a way to find out what is duplicate and get rid of it?
Scott Davis
View Scott Davis's profile on LinkedIn
Pat Horridge
Re: Redundant Avid media
on Apr 25, 2017 at 6:23:28 am
MDV is the app you need.
Pat Horridge
Broadcast & Post Consultant, Trainer, Avid Certified Instructor
Free online Tutorials at VET digital media academy online http://vimeo.com/channels/752951
pat@vet.co.uk
Eric Santiago
on Apr 27, 2017 at 12:12:59 pm
Thanks, Pat I was looking for something other than MediaMover.
Glenn Sakatch
on Apr 27, 2017 at 2:02:44 pm
Well, if they are truly redundant you can simply copy the the media to the same mxf numbered folder, and not have explorer overwrite anything. Any files left in the original spot would be duplicates.
Manually, you could drag the database from each folder to a bin and see what is there.
Glenn
Eric Santiago
on Apr 28, 2017 at 5:41:21 pm
[Glenn Sakatch] "Well, if they are truly redundant you can simply copy the the media to the same mxf numbered folder, and not have explorer overwrite anything. Any files left in the original spot would be duplicates.
An old practice that's bit me in the but in the past.
Ill give the freeware app a try.
