Exporting 29.97 and 59.94 timelines, should I reimport the footage for each?
Blake Rozo
on Mar 26, 2017 at 7:49:31 pm
Hey Folks,
So I'm experienced with Avid but not so much with small technicalities. I am trying to export two timelines for a documentary that is in the final stages of post: an Apple ProRes 422 in 29.97 fps, and another timeline at 59.94 fps. The raw footage is of varying dimensions and frame rates.
In a 29.97 project I reimported the footage at DNXHD 440 and will re-link to finish the post process, now for the 59.94 timeline, should I make a 59.94 project, and reingest everything again at 59.94 and relink to then export the 59.94 timeline?
Thanks so much for the advice folks.
Michael Phillips
Re: Exporting 29.97 and 59.94 timelines, should I reimport the footage for each?
on Mar 26, 2017 at 11:07:17 pm
Are your deliverables progressive or interlace? Or are you using frame rate as shorthand for 29.97 progressive and 59.94 interlace?
Michael
