Please Advise: Hardware/Software question about Avid Media Composer 8.4.5
David Carr
on Mar 8, 2017 at 4:42:07 am
I have a custom built Mac running an intel i7 sandy bridge with 32gb of RAM. I want to install Avid Media Composer 8.4.5 and cut 2k footage of off a firewire 800 drive.
question 1: can the i7 Sandy Bridge with 32gb of RAM handle the 2K footage? I think it should be fine, right?
question 2: what OS is compatible for 8.4.5? does it run on 10.12.3 Sierra?
question 3: what is the minimum Graphics card set up on this system^ cutting 2K?
thanks for any input.
Shane Ross
Re: Please Advise: Hardware/Software question about Avid Media Composer 8.4.5
on Mar 8, 2017 at 6:21:09 am
[David Carr] "question 1: can the i7 Sandy Bridge with 32gb of RAM handle the 2K footage? I think it should be fine, right?"
Yes.
[David Carr] "question 2: what OS is compatible for 8.4.5? does it run on 10.12.3 Sierra?"
That's a TAD too new for that version. I'd stick to 10.10 or 10.11 on your Hack for that version of Avid...
[David Carr] "question 3: what is the minimum Graphics card set up on this system^ cutting 2K?"
Avid doesn't really utilize the GPU like Resolve or Premiere. So it won't come into play here. Drive speed will, and FW800 will be cutting it a tad close..that's your biggest bottleneck. Just transcode the footage to ProRes MXF or DNxHD and you should be fine.
Shane
Little Frog Post
David Carr
on Mar 8, 2017 at 3:00:18 pm
Shane,
Thanks for the advice.
Here's a follow up, I know Sierra is only supported for Avid 8.6.5 , but do you think 8.4.5 will Run at least on Sierra? Or is it anyone's guess?
Shane Ross
on Mar 8, 2017 at 6:34:33 pm
Anyone's guess. The only person who will know will be the first one to try it.
Shane
Little Frog Post
