The movie contains video track with more than one video image description.
Roman Romanus
on Mar 2, 2017 at 10:26:15 am
Why Avid Media Composer still not AMA linking files with "more than one video image description". Finalcut Premiere Davinci - no problem.
AVID MC 8.4.4 on MAC PRO 32gb AMA link Quicktime Apple Pro Res HQ 1080p25. When some files AMA-link, Avid write in console - The movie contains video track with more than one video image description.Forcing sample provider mode for video. And in the bin column [video] is Pro RES . ( it should be Pro Res 1080p25).Video playing with lag with this AMA-link.
John Pale
Re: The movie contains video track with more than one video image description.
on Mar 2, 2017 at 1:53:25 pm
May be some bad metadata in the file thats confusing the AMA plugin. Can you render out a new file from DaVinci, since apparently you have access to that program?
Also, check the audio tracks in QT Pro. It's possible to inadvertantly encode a file to Apple ProRes with compressed audio instead of the usual uncompressed, and I have seen Avid have issues with this. Probably not the case here , but takes a second to check.
Roman Romanus
on Mar 2, 2017 at 6:21:30 pm
The files come from somebody who made it in FINALCUT. Some files are AMA-link perfectly. Some with this error. Its not bad metadada- files play in QT player, link -import in FINALCUT/ ADOBE PREMIERE/DAVINCI but not link in AVID. Only "fast import" to native QT PRORES HQ in 8.4.4 MC. I delete the audio and TC track from file and error stil in video/ I locate it in 15 frames QT mov file now and see in atombox viewer. ( in picture there 3 same entries what avid dont like but if it may be 1 avid linked it)
Roman Romanus
on Mar 7, 2017 at 1:21:39 pm
If the movie contains "more than 1" video description table it AMA link with wrong parametrs and play with lag. See in the pic video- PRO RES HQ is wrong- must be "apple prores hq 1080". The way is edit the header of the file if your need to AMA link it. The files fast imported normally (takes some times to copy file in AvidMediaFiles folder. But AMA is preffered.
