Is there a way to make multi/group clips of this?
Micke Engström
on Feb 2, 2017 at 4:59:08 pm
4 cameras, one sound, matching timecode.
Normally it´s easy to edit using Group/multigroup...
BUT in this Project the cameras are not rolling all the time - so there is empty spaces, which makes it impossible to group clips - or is it??
(This is only a part of the material, they filmed using this method for four Days.)
Is there a way to make a groupclip, or some other way to work smooth with this material?? I want to see all the cameras at the same time to edit faster...
Help!!!
Shane Ross
Re: Is there a way to make multi/group clips of this?
on Feb 2, 2017 at 6:37:36 pm
It's possible, you just need to lay out a sync map and use Super Grouper to do this. I have all sorts of clips like this on reality shows, but the AE's do it, so I don't know how it's done. SOmeone here will. Just wanted to say it's possible
Shane
Little Frog Post
Michael Hancock
on Feb 2, 2017 at 6:43:02 pm
Shane mentioned super grouper - here are some links to check out.
Super Grouper: http://www.avidsupergrouper.com/
Sync Map tutorial for multigroups:
https://viewfromthecuttingroomfloor.wordpress.com/2008/04/17/multigroups/
Michael Hancock
Editor
Micke Engström
on Feb 3, 2017 at 1:27:44 pm
Thanks!!
Super grouper is for mac only - I´m on a pc.
So I better start working, HOURS of tedious manual work for me to do.
Avid absolutly have things to develop here!!!!!!!!!!!
Michael Phillips
on Feb 3, 2017 at 1:32:42 pm
Once you have a timeline sync map set up, you can always use GroupItForMe:
http://www.groupitforme.com/
Michael
