EDL without EDL Manager
Marissa Gouverne
on Jan 12, 2017 at 7:31:41 pm
Hey all!
I'm working on Avid v7.0.6 and I'm trying to get an EDL out of my very complex timeline. I can't get EDL Manager to spit out all video tracks, but even after I flattened those I get an EDL that's riddled with errors. I have about ten audio tracks, which I can't really flatten. There's got to be a better way out there.
Also worth mentioning that this is a documentary and we're making an EDL mid-project in order to count up the in/outs of all of our archival footage and sound cues for licensing. It has to be fairly accurate or else we're going to have a lot of trouble. Any ideas?
Marissa Gouverne
Michael Phillips
Re: EDL without EDL Manager
on Jan 12, 2017 at 7:34:02 pm
Marissa -
Contact me at michael[at]24p[dot]com
Michael
Santiago Escudero
on Jan 15, 2017 at 4:41:27 pm
Why you don't try with an XML file? or even an AAF, just link media. XML is now a standar, and I'm sure it have the same information than a EDL.
Michael Phillips
on Jan 15, 2017 at 6:17:27 pm
The challenge is getting a file format that can be easily parsed for reporting on different needs like stock footage, music queues and such as mentioned by the OP. Media Composer does not have an official XML that is maintained, but there is one available via Avid FilmScribe. But with an XML, a parser is still needed to put it into a more usable format like Excel.
An EDL can be generated for each of the tracks if well organized, and Excel can take in an EDL using spaces as a separator as long as other metadata doesn't have spaces in it or each will be in its own column which may still be fine, but then you still need to create a formula for adding up etc.
AAF is a binary format that is not man-readable without a lot of engineering. Even going through the steps of using AAAF Dumper results in an overload of information that will take forever to go through if you don't understand the AAF structure. For example, the below is an AAF output of a single title. That's it, just one title, nothing else on the timeline. And you can see what I am referring to when parsing AAF:
AAF DLL path name: C:\AAF DUMPER\AAFCOAPI.dll
AAF DLL version : 1.1.6 (6995)
Dump of file: C:\AAF DUMPER\Single title.aaf
################## Summary Information #################
File has 6 mobs
File has 0 EssenceData objects
######################## Header ########################
ByteOrder: 18761
LastModified: Nov 11, 2015 18:50:32.00 GMT
Version: { 1, 1 }
IdentificationList: Strong Object Reference Array [1] of Identification
kAAFTypeID_IdentificationStrongReferenceVector [0]:
[ Identification ]
CompanyName: "Avid Technology, Inc."
ProductName: "Avid Media Composer 8.5b39345"
ProductVersion: { 8, 5, 0, 0, VersionBeta }
ProductVersionString: "Unknown version"
ProductID: { d0b7c06e-cd3d-4ad7-acfb-f03a4f42a231 }
Date: Nov 11, 2015 18:50:32.00 GMT
ToolkitVersion: { 1, 1, 6, 8830, VersionUnknown }
Platform: "AAFSDK (Win64)"
GenerationAUID: { 9fe593d1-fac3-4274-8941-653cf3980720 }
ObjectModelVersion: 1
######################## Mobs ########################
[ MasterMob ]
MobID: 060a2b340101010101010f00-13-000000-{ 56438db7-700d-1a91-060e-2b347f7f2a80 }
Slots: Strong Object Reference Array [2] of MobSlot
kAAFTypeID_MobSlotStrongReferenceVector [0]:
[ TimelineMobSlot ]
SlotID: 1
SlotName: ""
Segment:
[ EssenceGroup ]
DataDefinition: Picture
Length: 2877
Choices: Strong Object Reference Array [1] of SourceReference
kAAFTypeID_SourceReferenceStrongReferenceVector [0]:
[ SourceClip ]
Length: 2877
SourceID: 060a2b340101010101010f00-13-000000-{ 56438db7-700e-1a91-060e-2b347f7f2a80 }
SourceMobSlotID: 1
StartTime: 0
EssenceGroupType: 1
PhysicalTrackNumber: 1
EditRate: { 24000/1001 }
Origin: 0
kAAFTypeID_MobSlotStrongReferenceVector [1]:
[ TimelineMobSlot ]
SlotID: 2
SlotName: ""
Segment:
[ EssenceGroup ]
Length: 2877
Choices: Strong Object Reference Array [2] of SourceReference
[ SourceClip ]
Length: 2877
SourceID: 060a2b340101010101010f00-13-000000-{ 56438db8-721f-1a91-060e-2b347f7f2a80 }
SourceMobSlotID: 1
StartTime: 0
kAAFTypeID_SourceReferenceStrongReferenceVector [1]:
[ SourceClip ]
Length: 2877
SourceID: 060a2b340101010101010f00-13-000000-{ 56438db8-7309-1a91-060e-2b347f7f2a80 }
SourceMobSlotID: 1
StartTime: 0
EssenceGroupType: 1
PhysicalTrackNumber: 2
Origin: 0
LastModified: Nov 11, 2015 18:49:28.00 GMT
CreationTime: Nov 11, 2015 18:49:27.00 GMT
UsageCode: Usage_LowerLevel
ConvertFrameRate: False
MobAttributeList: Strong Object Reference Array [1] of TaggedValue
kAAFTypeID_TaggedValueStrongReferenceVector [0]:
[ TaggedValue ]
Value: (indirect type: aafString) "__AttributeList"
TaggedValueAttributeList: Strong Object Reference Array [11] of TaggedValue
[ TaggedValue ]
Value: (indirect type: aafInt32) 1
kAAFTypeID_TaggedValueStrongReferenceVector [1]:
[ TaggedValue ]
kAAFTypeID_TaggedValueStrongReferenceVector [2]:
[ TaggedValue ]
Value: (indirect type: aafInt32) 0
kAAFTypeID_TaggedValueStrongReferenceVector [3]:
[ TaggedValue ]
kAAFTypeID_TaggedValueStrongReferenceVector [4]:
[ TaggedValue ]
Value: (indirect type: aafInt32) 2
kAAFTypeID_TaggedValueStrongReferenceVector [5]:
[ TaggedValue ]
kAAFTypeID_TaggedValueStrongReferenceVector [6]:
[ TaggedValue ]
kAAFTypeID_TaggedValueStrongReferenceVector [7]:
[ TaggedValue ]
kAAFTypeID_TaggedValueStrongReferenceVector [8]:
[ TaggedValue ]
Value: (indirect type: aafString) "__PortableObject"
PortableObject:
[ NetworkLocator ]
URLString: "file:///C%3A/Users/Public/Documents/Shared%20Avid%20Projects/title-1a915f9d.PICT"
PortableObjectClassID: 1464421958
kAAFTypeID_TaggedValueStrongReferenceVector [9]:
[ TaggedValue ]
kAAFTypeID_TaggedValueStrongReferenceVector [a]:
[ TaggedValue ]
AppCode: 1
[ SourceMob ]
MobID: 060a2b340101010101010f00-13-000000-{ 56438db7-700e-1a91-060e-2b347f7f2a80 }
Slots: Strong Object Reference Array [1] of MobSlot
[ TimelineMobSlot ]
SlotID: 1
SlotName: ""
Segment:
[ SourceClip ]
Length: 2877
SourceID: 060a2b340101010101010f00-13-000000-{ 56438db7-700f-1a91-060e-2b347f7f2a80 }
SourceMobSlotID: 1
StartTime: 0
Origin: 0
LastModified: Nov 11, 2015 18:49:27.00 GMT
EssenceDescription:
[ CDCIDescriptor ]
Locator: Strong Object Reference Array [1] of Locator
kAAFTypeID_LocatorStrongReferenceVector [0]:
[ NetworkLocator ]
URLString: "file:///C%3A/Avid%20MediaFiles/MXF/1/title1447267767V056438DB7.mxf"
SampleRate: { 24000/1001 }
Length: 1
ContainerFormat: MXF
Compression: { 0e040201-0204-0100-060e-2b3404010101 }
StoredHeight: 1080
StoredWidth: 1920
SampledHeight: 1080
SampledWidth: 1920
SampledXOffset: 0
SampledYOffset: 0
DisplayHeight: 1080
DisplayWidth: 1920
DisplayXOffset: 0
DisplayYOffset: 0
FrameLayout: FullFrame
VideoLineMap:
[0]: 42 0
ImageAspectRatio: { 16/9 }
TransferCharacteristic: TransferCharacteristic_ITU709
ImageAlignmentFactor: 8192
ColorPrimaries: ColorPrimaries_ITU709
CodingEquations: CodingEquations_ITU709
ComponentWidth: 8
HorizontalSubsampling: 2
ColorSiting: Rec601
BlackReferenceLevel: 16
WhiteReferenceLevel: 235
ColorRange: 225
VerticalSubsampling: 1
OffsetToFrameIndexes64: 655591
SourceBox: { { -800/1 }, { -450/1 }, { 1600/1 }, { 900/1 } }
EssenceBox: { { -800/1 }, { -450/1 }, { 1600/1 }, { 900/1 } }
ValidBox: { { -800/1 }, { -450/1 }, { 1600/1 }, { 900/1 } }
DataOffset: 393216
FrameIndexByteOrder: 18761
FrameSampleSize: 606208
ImageSize: 606208
ResolutionID: 1237
[ SourceMob ]
MobID: 060a2b340101010101010f00-13-000000-{ 56438db7-700f-1a91-060e-2b347f7f2a80 }
Slots: Strong Object Reference Array [3] of MobSlot
[ TimelineMobSlot ]
SlotID: 1
SlotName: ""
Segment:
[ SourceClip ]
Length: 2877
SourceID: 000000000000000000000000-00-000000-{ 00000000-0000-0000-0000-000000000000 }
SourceMobSlotID: 0
StartTime: 0
Origin: 0
[ TimelineMobSlot ]
SlotID: 2
SlotName: ""
Segment:
[ Timecode ]
DataDefinition: Timecode
Length: 2877
Start: 86400
FPS: 24
Drop: False
Origin: 0
kAAFTypeID_MobSlotStrongReferenceVector [2]:
[ TimelineMobSlot ]
SlotID: 3
SlotName: ""
Segment:
[ SourceClip ]
Length: 2877
SourceMobSlotID: 0
StartTime: 0
Origin: 0
EssenceDescription:
[ ImportDescriptor ]
[ NetworkLocator ]
[ TaggedValue ]
Value: (indirect type: aafString) "Missing William"
[ SourceMob ]
MobID: 060a2b340101010101010f00-13-000000-{ 56438db8-7309-1a91-060e-2b347f7f2a80 }
[ TimelineMobSlot ]
SlotID: 1
SlotName: ""
Segment:
[ SourceClip ]
Length: 2877
SourceMobSlotID: 3
StartTime: 0
Origin: 0
CreationTime: Nov 11, 2015 18:49:28.00 GMT
EssenceDescription:
[ RGBADescriptor ]
[ NetworkLocator ]
URLString: "file:///C%3A/Avid%20MediaFiles/MXF/1/title144726776856438DB8.1.mxf"
Length: 1
StoredHeight: 1080
StoredWidth: 1920
SampledHeight: 1080
SampledWidth: 1920
SampledXOffset: 0
SampledYOffset: 0
DisplayHeight: 1080
DisplayWidth: 1920
DisplayXOffset: 0
DisplayYOffset: 0
VideoLineMap:
[0]: 42 0
PixelLayout:
aafRGBALayout[0]: { CompAlpha, 8 } { CompNull, 0 } { CompNone, 0 } { CompNone, 0 } { CompNone, 0 } { CompNone, 0 } { CompNone, 0 } { CompNone, 0 }
ComponentMaxRef: 235
ComponentMinRef: 16
OffsetToFrameIndexes: 2097383
DataOffset: 393216
FrameSampleSize: 2080768
ImageSize: 2080768
[ SourceMob ]
MobID: 060a2b340101010101010f00-13-000000-{ 56438db8-721f-1a91-060e-2b347f7f2a80 }
[ TimelineMobSlot ]
SlotID: 1
SlotName: ""
Segment:
[ SourceClip ]
Length: 2877
SourceMobSlotID: 3
StartTime: 0
Origin: 0
EssenceDescription:
[ CDCIDescriptor ]
[ NetworkLocator ]
URLString: "file:///C%3A/Avid%20MediaFiles/MXF/1/title1447267768V056438DB8.mxf"
Length: 1
StoredHeight: 1080
StoredWidth: 1920
SampledHeight: 1080
SampledWidth: 1920
SampledXOffset: 0
SampledYOffset: 0
DisplayHeight: 1080
DisplayWidth: 1920
DisplayXOffset: 0
DisplayYOffset: 0
VideoLineMap:
[0]: 42 0
ComponentWidth: 8
ColorSiting: Rec601
ColorRange: 225
DataOffset: 393216
ImageSize: 606208
ResolutionID: 1237
[ CompositionMob ]
MobID: 060a2b340101010101010f00-13-000000-{ 56438df7-6bf7-1a92-060e-2b347f7f2a80 }
Name: "Single title.Exported.01"
Slots: Strong Object Reference Array [11] of MobSlot
[ TimelineMobSlot ]
SlotID: 1
SlotName: ""
Segment:
[ Timecode ]
Length: 49
Start: 86400
FPS: 24
Drop: False
Origin: 0
[ TimelineMobSlot ]
SlotID: 2
SlotName: ""
Segment:
[ Pulldown ]
Length: 49
InputSegment:
[ Timecode ]
Length: 51
Start: 90000
FPS: 25
Drop: False
PulldownKind: PALPD
PulldownDirection: TapeToFilmSpeed
PhaseFrame: 0
ComponentAttributeList: Strong Object Reference Array [1] of TaggedValue
[ TaggedValue ]
Value: (indirect type: aafInt32) 25
PhysicalTrackNumber: 3
Origin: 0
[ TimelineMobSlot ]
SlotID: 3
SlotName: ""
Segment:
[ Timecode ]
Length: 49
Start: 86400
FPS: 24
Drop: False
Origin: 0
kAAFTypeID_MobSlotStrongReferenceVector [3]:
[ TimelineMobSlot ]
SlotID: 4
SlotName: ""
Segment:
[ Timecode ]
Length: 49
Start: 90000
FPS: 25
Drop: False
PhysicalTrackNumber: 4
Origin: 0
kAAFTypeID_MobSlotStrongReferenceVector [4]:
[ TimelineMobSlot ]
SlotID: 5
SlotName: ""
Segment:
[ Pulldown ]
Length: 49
InputSegment:
[ Timecode ]
Length: 61
Start: 107892
FPS: 30
Drop: True
PulldownKind: TwoThreePD
PhaseFrame: 0
[ TaggedValue ]
Value: (indirect type: aafInt32) 5
PhysicalTrackNumber: 5
Origin: 0
kAAFTypeID_MobSlotStrongReferenceVector [5]:
[ TimelineMobSlot ]
SlotID: 6
SlotName: ""
Segment:
[ Pulldown ]
Length: 49
InputSegment:
[ Timecode ]
Length: 61
Start: 108000
FPS: 30
Drop: False
PhaseFrame: 0
[ TaggedValue ]
PhysicalTrackNumber: 6
Origin: 0
kAAFTypeID_MobSlotStrongReferenceVector [6]:
[ TimelineMobSlot ]
SlotID: 7
SlotName: ""
Segment:
[ Pulldown ]
Length: 49
InputSegment:
[ Timecode ]
Length: 49
Start: 108000
FPS: 30
Drop: False
PulldownKind: OneToOneNTSC
PhaseFrame: 0
[ TaggedValue ]
PhysicalTrackNumber: 7
Origin: 0
kAAFTypeID_MobSlotStrongReferenceVector [7]:
[ TimelineMobSlot ]
SlotID: 8
SlotName: ""
Segment:
[ EdgeCode ]
DataDefinition: Edgecode
Length: 49
Start: 0
FilmKind: Ft35MM
CodeFormat: EtEdgenum4
Header:
[0]: 48 48 49 0 32 32 32 32
AvEdgeType: 1
AvFilmType: 0
Origin: 0
kAAFTypeID_MobSlotStrongReferenceVector [8]:
[ TimelineMobSlot ]
SlotID: 9
SlotName: ""
Segment:
[ Pulldown ]
Length: 49
InputSegment:
[ Timecode ]
Length: 122
Start: 216000
FPS: 60
Drop: False
PulldownKind: TwentyFourToSixtyPD
PhaseFrame: 0
[ TaggedValue ]
Value: (indirect type: aafInt32) 10
PhysicalTrackNumber: 8
Origin: 0
kAAFTypeID_MobSlotStrongReferenceVector [9]:
[ TimelineMobSlot ]
SlotID: 10
SlotName: ""
Segment:
[ Sequence ]
Length: 49
Components: Strong Object Reference Array [1] of Component
kAAFTypeID_ComponentStrongReferenceVector [0]:
[ OperationGroup ]
Length: 49
Operation: Title_2
InputSegments: Strong Object Reference Array [3] of Segment
kAAFTypeID_SegmentStrongReferenceVector [0]:
[ Sequence ]
Length: 49
[ ScopeReference ]
Length: 49
RelativeScope: 1
RelativeSlot: 1
Avid Scope: 1
kAAFTypeID_SegmentStrongReferenceVector [1]:
[ SourceClip ]
Length: 49
SourceID: 060a2b340101010101010f00-13-000000-{ 56438db7-700d-1a91-060e-2b347f7f2a80 }
SourceMobSlotID: 1
StartTime: 584
[ TaggedValue ]
Value: (indirect type: aafString) "<?xml version="1.0" encoding="UTF-8" standalone="no" ?> -800/1 -450/1 1600/1 900/1 -800/1 -450/1 1600/1 900/1 -800/1 -450/1 1600/1 900/1 -800/1 -450/1 1600/1 900/1"
kAAFTypeID_SegmentStrongReferenceVector [2]:
[ SourceClip ]
Length: 49
SourceMobSlotID: 2
StartTime: 584
[ TaggedValue ]
Parameters: Strong Object Reference Array [10] of Parameter
kAAFTypeID_ParameterStrongReferenceVector [0]:
[ ConstantValue ]
Definition: { a2e74203-8527-4f5a-aa16-4bac4607510f }
Value: (indirect type: Rational) { 546546547/1000000000 }
kAAFTypeID_ParameterStrongReferenceVector [1]:
[ ConstantValue ]
Definition: { 1fdd2907-e48c-11d3-a078-006094eb75cb }
Value: (indirect type: AvidBagOfBits)
[0]: 2 210 0 0 0 0 0 16 0 16 0 17 2 255 12 0
[10]: 0 0 2 210 0 0 0 0 0 0 0 0 0 16 0 0
[20]: 0 16 0 0 0 0 0 0 0 1 0 10 0 0 0 0
[30]: 0 16 0 16 0 161 0 101 0 14 65 86 73 68 0 1
[40]: 49 32 87 73 78 32 77 67 0 161 0 100 1 88 65
kAAFTypeID_ParameterStrongReferenceVector [2]:
[ ConstantValue ]
Definition: { 4856d427-23ef-4437-bed2-e829977f1561 }
Value: (indirect type: Rational) { 300800801/500000000 }
kAAFTypeID_ParameterStrongReferenceVector [3]:
[ ConstantValue ]
Definition: { 8d56812b-847e-11d5-935a-50f857c10000 }
Value: (indirect type: Boolean) True
kAAFTypeID_ParameterStrongReferenceVector [4]:
[ ConstantValue ]
Definition: { 8d56814d-847e-11d5-935a-50f857c10000 }
Value: (indirect type: Boolean) False
kAAFTypeID_ParameterStrongReferenceVector [5]:
[ ConstantValue ]
Definition: { 8d568153-847e-11d5-935a-50f857c10000 }
kAAFTypeID_ParameterStrongReferenceVector [6]:
[ ConstantValue ]
Definition: { c0038672-a8cf-11d3-a05b-006094eb75cb }
Value: (indirect type: aafUInt16) 18761
kAAFTypeID_ParameterStrongReferenceVector [7]:
[ ConstantValue ]
Definition: { 1f99097e-13b8-4ae8-98fd-c3512850edff }
Value: (indirect type: Rational) { 103103103/250000000 }
kAAFTypeID_ParameterStrongReferenceVector [8]:
[ ConstantValue ]
Definition: { 93994bd6-a81d-11d3-a05b-006094eb75cb }
[0]: 69 70 70 50 95 66 76 69 78 68 95 71 82 65 80 72
[10]: 73 67 0
kAAFTypeID_ParameterStrongReferenceVector [9]:
[ ConstantValue ]
Definition: { 760264de-f952-4525-9d3f-a4397080cb38 }
Value: (indirect type: Rational) { 19019019/50000000 }
ComponentAttributeList: Strong Object Reference Array [8] of TaggedValue
[ TaggedValue ]
[ TaggedValue ]
[ TaggedValue ]
[ TaggedValue ]
Value: (indirect type: aafInt32) 380
[ TaggedValue ]
Value: (indirect type: aafInt32) 412
[ TaggedValue ]
Value: (indirect type: aafInt32) -398
[ TaggedValue ]
Value: (indirect type: aafInt32) -453
[ TaggedValue ]
Origin: 0
kAAFTypeID_MobSlotStrongReferenceVector [a]:
[ TimelineMobSlot ]
SlotID: 11
SlotName: ""
Segment:
[ Sequence ]
DataDefinition: SoundMasterTrack
Length: 49
[ Filler ]
Length: 49
Origin: 0
LastModified: Nov 11, 2015 18:49:40.00 GMT
CreationTime: Nov 11, 2015 18:50:31.00 GMT
UsageCode: Usage_TopLevel
MobAttributeList: Strong Object Reference Array [7] of TaggedValue
[ TaggedValue ]
[ TaggedValue ]
Value: (indirect type: aafInt32) 9
[ TaggedValue ]
Value: (indirect type: aafString) "HD 1080p/23.976"
[ TaggedValue ]
Value: (indirect type: aafString) "<?xml version="1.0" encoding="UTF-8" standalone="no" ?> -800/1 -450/1 1600/1 900/1"
[ TaggedValue ]
[ TaggedValue ]
Value: (indirect type: aafInt32) 32769
[ TaggedValue ]
######################## EssenceData ########################
End of file: C:\AAF DUMPER\Single title.aaf
Shane Ross
on Jan 17, 2017 at 2:32:37 am
[Santiago Escudero] "Why you don't try with an XML file? or even an AAF, just link media. XML is now a standar, and I'm sure it have the same information than a EDL."
Avid doesn't export, nor import, XML. Just FYI
Shane
Little Frog Post
Richard Sanchez
on Jan 17, 2017 at 2:11:12 am
Can you export more than one EDL? When I do turnovers, I usually export one EDL per video track, and one EDL for every four audio tracks. It's not fun, but I've used this method for picture and sound turnovers. By the same note, you should be able to use this for your archival tracks.
Richard Sanchez
Los Angeles, CA
"We are the facilitators of our own creative evolution." - Bill Hicks
Marissa Gouverne
on Jan 17, 2017 at 3:50:42 pm
Might have to. That's not what my archival team wants because that can get pretty clunky when they're trying to order masters (i.e. if the audio of a clip extends past the length of the video), but it's not looking like there's a decent alternative while the timeline is kind of a mess and EDL Manager is being this difficult. I'll work it out today and see if that'll solve the problem, however.
Thanks everyone!
