25fps in 23.976 project
Pieter Viljoen
on Jan 11, 2017 at 2:09:10 am
I've been looking for a way to do this, but I have stringouts of footage shot at 25FPS that I've tried to bring into a 23.976 project where I also have a lot of 23.976 footage.
In the past I would just bring in the bin into the frame rate I want to work at, and since finish is at 23.976 I was going to edit in that timebase. I'm getting the Modify error saying it can't do it. Is it because it's a sequence?
Would I have to bring in the actual 25fps dailies and eyematch the selects? I thought I've done this many times before but I could be misremembering...
Michael Phillips
Re: 25fps in 23.976 project
on Jan 23, 2017 at 12:50:26 am
Did you try loading it up as a sequence first so it gets converted to a 23.976 sequence, then load the converted sequence as source?
Michael
