canon c100 25psf interlaced delivery best option
Massimo Alberto Croce
on Jan 2, 2017 at 9:39:36 pm
Hello guys,
I have a project to set up and i need some advise for the workflow.
For an interlaced 1080i 50 output, considering most footage coming from a c100 25PF (i think canon mean 25psf)
is better to change the field motion to progressive and ingest (transcode via ama) as progressive P DNxHD or leave it interlaced?
thanks in advance
Video Editor, Colorist, Pro Tools Editor
massimoalberto.croce@gmail.com
Bouke Vahl
Re: canon c100 25psf interlaced delivery best option
on Jan 5, 2017 at 5:32:12 pm
It does not matter, you get a motion adapter when you switch to interlaced.
Edit in interlace if you're output has to be interlaced. This will render your effects interlaced, and that will look better on an interlace display.
Bouke
http://www.videotoolshed.com/
smart tools for video pros
on Jan 6, 2017 at 11:46:52 pm
Thanks for the info!
Job ter Burg
on Jan 5, 2017 at 6:00:40 pm
It's really simple to create a 1080i50 signal from a 1080p25 sequence. That said, you'll need to take into consideration whether or not you want your program to stay progressive all the way through. Meaning that there is a motion difference between any DVE moves, title rolls/crawls, wipes, pushes, etc. In 1080p25, these move in 25 steps/second, in 1080i50, these move in 50 steps per second (quite a bit smoother). Some broadcasters require titles be done in 1080i50.
