can't see playback. seeing ghost images instead
Yehonatan Yovel
on Dec 31, 2016 at 6:06:38 pm
can't see anything in the composer video, just ghosts of whatever goes through it. audio works fine. my specs are:
Windows 10 NVIDIA GeForce GTX 650 plenty of ram
tried updating the drivers, didn't change.
tried reinstalling, didn't change.
***avid used to work fine, then I stashed my pc for couple of months and after turning it back on it stopped working. can my graphic card be damaged? I also have an Intel HD 4600 in this pc, tried switching to it and still nothing changed... any ideas?
Glenn Sakatch
Re: can't see playback. seeing ghost images instead
on Jan 2, 2017 at 4:48:37 pm
could be a video card or ram issue.
Have you tried re-seating anything?
Is this across multiple projects?
Your timeline looks like there is a bit going on including an entire track that needs to be rendered. Have you tried a simple 1 track timeline to see if that helps?
Newer versions of Avid also have a setting which allows you to flush the memory. That might be worth a shot.
Glenn
