Freeze frame Avid MC6 question
Sheree Day
on Nov 9, 2016 at 6:51:57 am
Just wondering if it's possible to grab a freeze frame from the Record monitor in AVID MC6?
Why you ask?
After laying out everything on the timeline I add a watermark in the lower thirds left side, and I need an image of one shot within the sequence to make a jpeg (or any image format not just jpeg - it can be TIFF etc).
When I put the playhead over the timeline and click on the record monitor and go to clip / freeze frame, the freeze frame is grey so I can't use it.
I did put the image full screen and do a screen shot, but I was wondering if it's possible to do it within Avid?
Thanks in advance for assistance.
Ricky Barrow
Re: Freeze frame Avid MC6 question
on Nov 9, 2016 at 12:38:43 pm
You can "Export" a graphic file - many choices: JPEG, PNG etc.
Ricky
Glenn Sakatch
on Nov 9, 2016 at 2:38:03 pm
Here is how i've done it for years...bit of a PITA, but in reality, it takes about 5 to 10 seconds total.
mark an in/out point on your timeline to get a duration of 1 frame at the point you want to freeze.
Then create a video mixdown of that section (because its only 1 frame it takes up hardly any space, and is instantaneous)
load that video mixdown in the source viewer
create a freeze frame of that
Glenn
Sheree Day
on Nov 10, 2016 at 6:17:44 am
Thanks Glenn that was brilliant - I tried and it worked perfectly
