Sony plug-in issue
Adam Harper
Sony plug-in issue
on Sep 20, 2016 at 8:02:00 am
Hi all
I've installed a plug-in (Sony_PDZK-MA2_v.3.32) on multiple computers in order to make AVID compatible with footage from the Sony FS7. I've used some footage as a test to make sure it was all working (they were in an XAVC MXF format) and all but one worked. When I attempted to AMA-link to the footage, it just said; "There were errors AMA-linking to the footage" and nothing else.
All the versions of AVID are the same (7.0.4), however I should point out that this computer in particular is on a different version of OS (Mavericks, 10.9.5) to the rest so my initial guess is that it probably has something to do with that. Does anyone have an idea on what might be causing this error that it won't provide me any details about?
Here is a screenshot of the console if that helps;
Adam Harper
Re: Sony plug-in issue
on Sep 22, 2016 at 8:08:02 am
Bump.
Michael Phillips
on Sep 22, 2016 at 1:24:40 pm
It indicates you used Autodetect and suggests you select the AMA plug-in directly before linking.
Michael
Adam Harper
on Sep 22, 2016 at 1:34:55 pm
Hi Michael
Sorry, I forgot to mention in my original post. In the files of type section I selected 'Sony XAVC_XDCAM (*.mxf)' for all the computers and I got the same result.
John Pale
on Sep 25, 2016 at 3:17:01 pm
Try deleting the AMA Management folder
Windows: C:\Users\Public\Documents\Avid Media Composer\AMA Management
Mac: HD/Users/Shared/AvidMediaComposer/AMA Management
Sometimes errors will persist until you do this.
Adam Harper
on Sep 25, 2016 at 6:07:03 pm
Okay I will try that. Will AVID automatically reconstruct the folder or do I need to follow up this with another action to recreate it?
John Pale
on Sep 26, 2016 at 2:29:34 am
It reconstructs. Its not terribly useful for most users anyway.
Adam Harper
on Sep 26, 2016 at 2:43:36 pm
That's fixed it! Still none the wiser as to what the original error was but no matter, it works now.
Thanks John.
