Autosync not working properly
Vicky Peters
on Sep 15, 2016 at 12:29:47 pm
Hi everyone,
I'm trying to autosync this subsequence to turn it into a synched subclip but for some reason the Avid leaves off my audio tracks when I autosync two particular subsequences. I've checked - the audio tracks are selected when I autosync, there are no extra bits of video lying around etc. It worked fine with a few other subsequences I have pulled from the same long sync sequence as the problem clips. Any insight?
Thanks so much x
Michael Phillips
Re: Autosync not working properly
on Sep 15, 2016 at 1:23:02 pm
Are there any adapters on that particular subsequence? All events on each track are of the same duration (should be if sub-sequencing)? Audio tracks are of the same sample rate?
Michael
