Why Avid MC 8 consolidates audio files when I choose copy all?
Brigitta Bacskai
on Aug 11, 2016 at 10:42:52 am
I've been using MC for many years , I always chose the same method for making AAF for post sound: Include audio, all tracks, use marks, use selected tracks, aaf edit protocoll, copy all media, same folder as aaf. It always worked with MC 7 and previous and now, with 8 it keeps consolidating the audio files to 60 frames.
Does anyone have any solution for this?
Shane Ross
Re: Why Avid MC 8 consolidates audio files when I choose copy all?
on Aug 11, 2016 at 4:56:24 pm
Can you post a picture of all your AAF export settings?
Shane
Little Frog Post
Brigitta Bacskai
on Aug 11, 2016 at 6:26:10 pm
this one was the first. Then I tried with converted audio sample rate 48, bit depth 24 and file format to WAV, and also without the AAF protocol but I got the same 60 frame consolidated files.
John Pale
on Aug 12, 2016 at 4:15:25 am
Try new a different User Setting or create a new setting.
Brigitta Bacskai
on Aug 12, 2016 at 10:11:44 am
Thanks, I forgot to mention but I already tried that, too. Not working.
Job ter Burg
on Aug 15, 2016 at 7:05:04 am
Which version specifically? Might be a resurfacing bug.
Brigitta Bacskai
on Aug 15, 2016 at 11:06:44 am
The version is 8.5.3. So only downgrade would help?
b.
Job ter Burg
on Aug 16, 2016 at 10:41:19 am
No, I'm not saying that. I have had similar issues in v7.something.
