OT - problem connect w a MacBook to a Sata raid via USB3 or…?
Paul Dougherty
on Aug 10, 2016 at 12:56:44 pm
I was running a Avid on a G5 for legacy NTSC work and the G5 died. I was using a 5 drive raid (not striped but JBOD). As a alternative/replacement I tried a Startech USB 3 0 to eSATA Cable to connect to a fairly new MacBook (w USB3 & Thunderbolt) 2.5 Ghz Intel Core i5 w OS 10.9.5). It only sees one of the 5 drives. I called the person I bought the raid from who I have a high regard for (should have done that earlier) and he seemed skeptical about USB 3 and thought using a Thunderbolt connection / adaptor to would be better. (he suggested the AKiTiO below)
It's more expensive and ties up the port I would like to use for a 2nd monitor. Is there anything I can try before I give up on the USB 3 to Sata StarTech adaptor?
Paul
AKiTiO Thunder SATA Go Hub SSD Reader with Tethered Thunderbolt Cable and 2x eSATA Host Ports
I am using the….
Startech USB3S2ESATA 3 ft SuperSpeed USB 3 0 to eSATA Cable
Shane Ross
Re: OT - problem connect w a MacBook to a Sata raid via USB3 or…?
on Aug 11, 2016 at 1:05:38 am
You don't want the device you mentioned...wrong Atikio box. You want this one:
https://www.akitio.com/adapters/thunder-dock
Has two eSATA ports, and two THUNDERBOLT ports, so you can daisy chain it...connect it to the computer and the monitor to it.
Shane
Little Frog Post
Paul Dougherty
on Aug 11, 2016 at 1:41:35 pm
Wow Shane, this seem great, thank you!
There seems to be a Akitio Thunder2 Dock, I'm in transit and will study but it would appear the original does everything I need and would cost less, thoughts anyone?
Best,
Paul
http://www.bhphotovideo.com/c/product/1111336-REG/akitio_ak_t2d_thsb3ias_ak...
Shane Ross
on Aug 11, 2016 at 4:55:26 pm
Yep...that's the one you want.
Shane
Little Frog Post
Paul Dougherty
on Aug 22, 2016 at 2:35:52 pm
Strangely the Thunder SATA Go successfully mounted all five drive in the raid but the Thunder Dock only mounts the last of the 5 (just like the usb3 adaptor). I wrote AKiTiO and they said the Go uses a different chip set. I really would like to make the Thunder Dock work to drive the 2nd monitor, we'll see.
Paul
