Choppy Playback in 8.6.1
John Keating
on Aug 7, 2016 at 1:16:49 pm
I recently upgraded from 8.4 to 8.6.
Everything was running fine and then today when I went to play my files they played back choppy. I reduced the resolution to the lowest setting and that fixed it for the moment.
I have a GTX 670 card and 24 gigs of ram. Im using the suggested driver that works with 8.4.
Not sure what to look for next.
John Keating
Re: Choppy Playback in 8.6.1
on Aug 7, 2016 at 1:45:43 pm
It appears that I solved this problem. However, I don't understand how.
The only files that were running choppy were files shot on the c300 (XF files).
I downloaded the new ama link for it and it appears that I have solved the issue. I just don't understand why it worked. All the files I was running were consolidated into the preferred .mxf files that Avid loves so dearly.
Why would the ama link update for canon fix such a thing? Weren't those files converted and no longer being referenced via ama link?
