Copy & Paste Markers on Multigroups
Reena Mang
on Jul 22, 2016 at 3:43:15 am
How do I copy markers from one avid multi group to another? They are identical. A 'select all, copy and paste " from one marker window to the other has not been working.
Thank you!
Gene Rosati Jr.
Re: Copy & Paste Markers on Multigroups
on Jul 22, 2016 at 8:21:04 pm
I'm also having the same problem. Hopefully there is a solution to this.
Reena Mang
on Jul 22, 2016 at 9:33:24 pm
I figured it out: load the group with markers into a sequence, change the start TC of the sequence to the start TC of the group. Open the sequence's marker window, select all and copy the markers. Load the group you want to paste the markers onto in the source monitor. Open that group's marker window, hit paste, and the markers populate with the exact time codes.
Gene Rosati Jr.
on Jul 22, 2016 at 9:47:54 pm
That worked! Great solution! Thank you!
Mike Mohr
on Aug 8, 2017 at 6:26:07 pm
wow- needed to do this and quickly found your instructions and they worked perfectly- thank you!
lance pereira
on Apr 29, 2019 at 8:03:42 pm
that worked perfectly. thanks, reena!
