How Do I Add Filler Between Two Clips on Timeline?
Gabrielle Mitchell
on Jun 20, 2016 at 10:04:11 pm
Hi, I'm wondering if someone could help me find the "add filler" option in AVID 8.3.1. I don't want to add filler to the beginning of a sequence but between two clips. Thanks for any help.
Where there is no struggle, there is no strength.
Stacy Lincoln
Re: How Do I Add Filler Between Two Clips on Timeline?
on Jun 21, 2016 at 12:00:13 am
You should be able to insert the filler anywhere. Set an "in and out" when you call up filler and hit the yellow insert arrow key. If that doesn't work....make a quick "title" in the title tool and insert that.
John Pale
on Jun 21, 2016 at 12:18:07 am
"Load Filler" in the source monitor. Insert Edit between two clips.
Glenn Sakatch
on Jun 23, 2016 at 7:05:55 pm
even more specifically. Right click on your source monitor and select load filler.
Glenn
