Are these avid quicktime codecs safe to download/use?
enrique bartolo
on Apr 19, 2016 at 3:32:06 am
I'm a windows user and I had to uninstall Quicktime because Apple is refusing to support it etc etc. So I found these avid quicktime codecs and I was wondering if I can just download and use the codecs for exporting videos in Davinci Resolve 12 lite.
http://avid.force.com/pkb/articles/en_US/download/Avid-QuickTime-Codecs-LE
If anyone can let me know if it's okay to download them, then that'll be swell!
Eric Santiago
Re: Are these avid quicktime codecs safe to download/use?
on Apr 19, 2016 at 3:59:48 am
They are the same.
Shane Ross
on Apr 19, 2016 at 4:24:05 am
You can download them, but they won't work unless you have Quicktime installed. They aren't separate. Quicktime is a container, as well as an application. The codecs only work inside that container...and they will only work if you have QT installed.
Shane
Little Frog Post
enrique bartolo
on Apr 19, 2016 at 8:06:07 am
Isn't there like a work around to install QuickTime for just its codecs?
