Avid Drag Trimming
Peter Williams
Avid Drag Trimming
on Mar 29, 2016 at 2:48:10 pm
Does anyone know if there is a way of drag trimming (using the mouse), so that the trim head doesn't stop at every edit?
I have a music track that I have cut into multiple times when making adjustments to a scene, and I need to drag it from the first edit point to the end of the scene.
I have a feeling there is a key that needs to be held down, during the process, but I can't for the life of me remember what it is (assuming it actually exists?!).
Many Thanks
Peter
Juris Eksts
Re: Avid Drag Trimming
on Mar 30, 2016 at 12:56:40 pm
I don't think there is a quick way of trimming, but if you mark in and out on the entire clip, then:
either 1, match frame and replace the clip, or
2, in the audio mixer drop down menu - remove pan and volumes on entire clip, then in the clip menu - remove match frame edits.
Peter Williams
on Mar 30, 2016 at 1:09:21 pm
Thanks Juris, I've have asked around, and there seems to be solution beyond doing what you have described1
Glenn Sakatch
on Mar 30, 2016 at 6:47:19 pm
just remove match frame edits on your audio track
Glenn
Juris Eksts
on Mar 30, 2016 at 9:56:50 pm
Hi Peter, let us know when you find out.
Peter Williams
on Mar 31, 2016 at 8:00:39 am
A FB forum suggests using extend edit or turning off snapping in the timeline settings. Someone posted this…
http://www.steves-digicams.com/knowledge-center/how-tos/photo-software/how-...
John Pale
on Mar 30, 2016 at 10:36:26 pm
You don't need to drag at all. Just use Extend Edit and the clip will trim magically to wherever your play head is.
For more information, search Your Avid Help.
