MXF files Media Composer Mac
Manuel Estevez
on Mar 2, 2016 at 2:56:50 am
I recently started learning the basics of Avid Media Composer. For that purpose I was working on Windows and everyhthing went ok. However, today I wanted to use my project and mediafiles on a mac and my medias keep saying they're offline. I tried creating a Medafiles folder (/Avid MediaFiles/MXF/1) in the root of my mac volume but Avid doesn't recognice it. Any idea of what should I do?
Glenn Sakatch
Re: MXF files Media Composer Mac
on Mar 2, 2016 at 3:22:15 pm
Double check your spelling of the folder.
You can also open Avid and create and render a text element, or import a still, and let Avid create the folder for you. This may tell you if you have some rights issues with the drive.
Glenn
Bill Ravens
on Mar 2, 2016 at 10:19:28 pm
The fundamental problem I've experienced when transferring files from PC to MAC, is the permissions. I suspect you need to allow your MAC system RW access to those hard drives and files.
