HD film to NTSC 48KHZ Anamorphic?
Louis Waters
on Feb 18, 2016 at 3:40:28 pm
Hi I was told I need to convert my HD film to NTSC 48KHZ Anamorphic in Avid. How do I do this?
I think I might have to either open an NTSC 30i project or open it in a 1080p 29.976 instead.
Could someone run me through the steps?
Thanks in advance.
Shane Ross
Re: HD film to NTSC 48KHZ Anamorphic?
on Feb 18, 2016 at 5:09:40 pm
Create a new project...30i NTSC...aspect Ratio 16:9.
AMA link to your file, and then transcode. OR...if you are talking about a sequence, copy the bin containing that sequence to the new project, and open.
Shane
Little Frog Post
Louis Waters
on Feb 18, 2016 at 7:09:55 pm
Thanks! I've transcoded the sequence but when exporting should I use "Same as source" or use a custom width and height?
Shane Ross
on Feb 18, 2016 at 8:50:56 pm
Same as source, I'd think.
Shane
Little Frog Post
Louis Waters
on Feb 18, 2016 at 8:55:22 pm
Works perfect thank you!
