Export settings for DNxHD 185 X?
Ada Ya
on Jan 26, 2016 at 4:13:36 am
I'm trying to export a sequence with transcoded DNxHD 185 X media.
The original files are AVCHD 1080p 50i.
My goal is to get as high quality as possible.
Preferably quality that will go for TV-broadcasting.
Adam
Shane Ross
Re: Export settings for DNxHD 185 X?
on Jan 26, 2016 at 4:30:34 am
AVCHD is an 8 bit codec. DNx185X is a 10 bit codec. Not really necessary in your case, quality won't improve over simply DNx185 (no X). But that is a fine finishing codec.
Shane
Little Frog Post
Ada Ya
on Jan 26, 2016 at 5:15:39 am
Okay, is it completely unnecessary to have a 10 bit codec,
even when I add color correction?
Shane Ross
on Jan 26, 2016 at 5:52:08 am
Well, that's always up for debate. I've never noticed a difference when I grade 8 bit source codecs in an 8-bit conversion codec, vs doing it as 10-bit. But that's if you don't push things much. If you do, I guess going 10-bit will help keep the banding issues lower. I guess it all depends on how much you are going to push the grade.
Shane
Little Frog Post
Ada Ya
on Jan 26, 2016 at 6:43:24 am
I'm quite new to color grading.
What do you mean by push?
Shane Ross
on Jan 26, 2016 at 6:22:05 pm
[Ada Ya] "What do you mean by push?"
Manipulate. You have an image, and you want to make it bluer, or brighter..or both. You PUSH the colors towards blue...PUSH the Luma (brights) higher...or perhaps the Mids (Gamma).
Shane
Little Frog Post
