AMA link won't work - XDCAM 422 MXF files - need plug in - Suggestions please
Zoe Westley
on Jan 19, 2016 at 6:02:05 pm
Hi everyone
I am trying to AMA link to footage shot on the Canon C300, but my avid keep coming up with error messages
Unable to autodetect plug-in for, you may need download & install the AMA plug in from the Avid AMA website
I've been searching but can't find the correct AMA plugin for this avid version I am using. Please help
I have Avid MC8.3.1
anyone have a link?
thank you
Shane Ross
Re: AMA link won't work - XDCAM 422 MXF files - need plug in - Suggestions please
on Jan 19, 2016 at 6:08:48 pm
Here:
https://www.avid.com/US/products/avid-media-access
And download and install ALL of them. I'm sure that you might only need the MXF OP1a plugin, and Canon plugin...perhaps also the Sony one. But I recall not being able to do this when only installing the Canon one. So I installed everything and it worked. Plus, it doesn't hurt anything to have them all.
Shane
Little Frog Post
Zoe Westley
on Jan 19, 2016 at 6:49:26 pm
thanks Shane - i did go to this page but didn't realise I would have to install all of them -ouch, I was hoping for a one stop install solution - i had better get going.
quick question, for AMA linking then transcoding the media from other sources, would you say Source Scaling Half - would be an okay setting for a 1920x108o delivery - material orginally shot on 4K and 2K. I seem to suddenly have e a lot of cameras to deal with, its gonna be a long night
thanks so much for all your help, i really appreciate it.
Zoe Westley
on Jan 19, 2016 at 7:19:05 pm
Hi Shane
OP1a MXF files plugin won't install neither will AVCHD - the error message is
no supported editors no compatible avid editor could be found
any suggestions?
Zoe Westley
on Jan 19, 2016 at 7:58:26 pm
Hi Shane/Michael/any other lovely person out there?
I've installed all the plugins on the page except the Arri ones, i don't seem to have any old plugins installed, so that can't be creating a conflict.
but the
"no supported editors no compatible avid editor could be found" - I really need to watch the rushes tonight. any help would be massively appreciated
thank you
Michael Phillips
on Jan 19, 2016 at 8:17:53 pm
The OP1a MXF gets installed natively with each version of Media Composer. The one on the AMA page refers to versions prior to v6.5. v6.5 was released in September 2012. Avid should really remove the MXF from the main landing page as it is misleading so many years later.
That being said, I was helping someone from Facebook with a similar issue where I could see the files via XMF AMA and she couldn't. I believe she ended up updating to latest release of MC 8.4.x.
Michael
Michael Phillips
on Jan 19, 2016 at 8:19:09 pm
Also, NEVER use Autodetect. Select each AMA plug-in manually when testing them, this is especially true with MXF wrapped formats.
Michael
Zoe Westley
on Jan 19, 2016 at 8:33:38 pm
Thanks Michael, just as you sent this message, i had worked it out. process of elimination. THANK YOU< YOU ARE GODS
have an amazing evening
zoe
Michael Phillips
on Jan 19, 2016 at 8:41:02 pm
In reference to the full detail, I would recommend you do use FULL. Other than RED R3D media, anything less than FULL does create small jaggies on other formats and the transcode times are barely any different. So no advantage.
Michael
Zoe Westley
on Jan 19, 2016 at 8:46:51 pm
thanks Michael - i'll do that
so i think i spoke to soon - i now have an error message that the AMA linked files won't consolidate
it says all files were skipped - see console - then this is the console message
here is the error message
The clip A001C019_160117BN_CANON was skipped during the Consolidate operation because it is of a foreign compression type.
Zoe
Michael Phillips
on Jan 19, 2016 at 8:53:54 pm
Ugh.... I think we established these were not 24.000 fps, correct? And when you link, can you see the media when you load a clip or do you get the same error message?
Michael
Shane Ross
on Jan 19, 2016 at 8:56:37 pm
24.000fps gives the FOREIGN COMPRESSION TYPE error? Lordy...
Shane
Little Frog Post
Zoe Westley
on Jan 19, 2016 at 9:07:50 pm
Hi both - yes i've been told that all the canon C300 footage is 25fps. I have set up 1080p/25 project. I can see all the clips when i load them and they seem to play okay. all looks good it just won't let me consolidate any of it.
The Sony Fs7 footage has mixed frame rates - all seems okay and plays fine. I will start transcoding.
Go Pro and Drones are all mixed frame rates - again all seem fine when i load the clips but they stutter - so i have started transcoding
thanks
Massimo Alberto Croce
on Jan 19, 2016 at 10:57:16 pm
Have you tried to transcode insted of consilidate?
Video Editor, Colorist, Pro Tools Editor
massimoalberto.croce@gmail.com
Zoe Westley
on Jan 19, 2016 at 11:21:00 pm
Hi
yeah that works, its just taking forever. but at least its working. strange about the consolidating, i was hoping for a short cut - oh well. have to move on, at least the transcoding seems to be working :)
on Jan 20, 2016 at 2:42:40 pm
This mean that you have somthing wrong with ama plug in or codec.try to uninstall and reinstall it
