my C drive gets full
baskar sivakumar
on Jan 16, 2016 at 7:38:39 pm
Even though I export my Quicktime project in another drive(f:drive)my c:drive is getting full automatically i tried to clean my avid attic folder but my problem still remains please help :(
Michael Phillips
Re: my C drive gets full
on Jan 16, 2016 at 11:03:12 pm
How full is it before attempting an export?
Michael
baskar sivakumar
on Jan 19, 2016 at 4:44:15 pm
Ty for your reply Michael my c drive had 15 GB free space before exporting after exporting its 10 mb ! Can you give a solution
Pat Horridge
on Jan 19, 2016 at 4:53:11 pm
Yup easy. You need to upgrade your boot drive.
15GB is nothing nowadays.
You need to either clear a lot of stuff off the C drive or upgrade to a larger boot drive.
With a 500GB boot drive I'd expect to have between 300-150GB free
Pat Horridge
Technical Director, Trainer, Avid Certified Instructor
Free online Tutorials at VET digital media academy online http://vimeo.com/channels/752951
VET
Production Editing Digital Media Design DVD
T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US
Michael Phillips
on Jan 19, 2016 at 5:06:03 pm
Sure, getting a bigger drive may work for some and not for other if they are working on a laptop, etc. It is a reasonable request that Media Composer allow you to place the Attic, AMA links, waveforms, and such to a different drive. It is possible to do so with Search Data Folder, just extend that to other similar cached items.
One thing to try if you're doing a lot of AMA and seeing some performance issue is turning off AMA management:
http://avid.force.com/pkb/articles/en_US/How_To/How-to-disable-AMA-Managed-...
That was one of those features added to a previous release with no real explanation anywhere as to what that meant and come to find out it was to help Interplay type scenarios... so at least get some performance back.
Michael
Pat Horridge
on Jan 17, 2016 at 11:26:48 am
Pretty sure QT exports create a tmp file on the OS drive then transfer to the destination drive.
You need 120% or more free space on the OS drive based on the expected export file size.
Pat Horridge
VET
brian waz
on Jan 19, 2016 at 4:18:34 pm
I too am finding my C:\ drive keeps getting full, especially when I use a lot of RED files via AMA. Is there a way to alter the path of the AMA Management folder or the Attic without re-installing the Avid software? (MC Symphony 8.3) It would be great to have those go to my media drives instead of my c:\
baskar sivakumar
on Jan 19, 2016 at 4:48:38 pm
Thanks pat if I import my videos instead of linking will this prob gets solved
Pat Horridge
on Jan 19, 2016 at 5:10:39 pm
As Michael says turn of AMA management.
Import isn't the same as AMA so you need to understand the impact that has later on in the workflow.
One other thing to try is to change the general setting in MC to have a different tmp directory. That may help.
Pat Horridge
VET
