Canon C300 H264 to Avid MC8.3 work flow questions
Zoe Westley
on Jan 15, 2016 at 8:48:17 pm
Happy new year everyone
I have a technical workflow question that i was hoping someone can help me with.
I am going to be editing a small 5min music video that is being shot on the Canon C300 camera. They will be shooting HD 1920x1080 - not 2K or 4K. my question is what is the best way of converting the H264 footage at 1:1 quality so that i can edit it in avid MC.
I am using Avid MC8.3
Imac retina 5K, 16GB
I want to edit at 1:1 as I need to export an HD QT that will be graded.
(We don't have time to work offline and conform on this project)
I will export a Same as Source (DNXHD QT) for grading
thanks so much
Zoe
Shane Ross
Re: Canon C300 H264 to Avid MC8.3 work flow questions
on Jan 15, 2016 at 8:57:24 pm
The C300 shoots XDCAM 422 MXF files, not H.264. I work on two shows that use this camera. For one we work in offline quality, but for the other, full resolution. So for that one we AMA Link and then CONSOLIDATE...don't transcode. XDCAM 422 is a native resolution in Avid...and MXF is the native format, so we consolidate to basically put it into the Avid File Structure, and then edit full resolution.
NOW...when you export for grading, depending on how you do it, you can export an AAF linked and give them the drive and that file, and Resolve will import and work with the footage without converting anything. OR...you can do a Video Mixdown to DNxHD 220 and export SAME AS SOURCE QT for grading. You can't export SAME AS SOURCE XDCAM, as same as source doesn't work with GOP formats, and XDCAM is a GOP format.
Shane
Little Frog Post
Zoe Westley
on Jan 15, 2016 at 10:22:59 pm
Hi Shane
thanks for your speedy response,massively appreciated
I was under the impression that the Canon C300 creates H264. is it just the compression that is H264 - if so that might be a problem as they are shooting on location and need to upload the rushes to me every night. will the file sizes be massive? it looks like 43mins of shooting(1920x1080 4.2.2) will create approx 23GB off data. Does that sound about right?
on the other side, thats better for me being avid friendly
so workflow wise, i've never had much luck with link to AMA and then consolidating. I find the AMA link too slow and sluggish - especially on an iMac. Please can you talk me through the process/options you use - it would be massively appreciated. I'm only working on an iMac for this project, although i anticipate that there won't be much footage at all.
Exporting as a linked AFF Sounds a great idea, I'll ask the Grade if they can work with that. alternatively if i do a mix down at Video Mixdown to DNxHD 220 - would that be high enough quality?
thanks so much for your help
Zoe
Zoe Westley
on Jan 15, 2016 at 10:38:46 pm
sorry i should have also said, how i normally link to AMA is
Create bin - File - AMA Link - change file type to Quick time - find the folder on my drive and click open.
I find that working this way can be quite sluggish with large files. Although i have only ever worked withQT this way, maybe XDCAM will be more efficient? is there anything different i should be doing?
thanks
Michael Phillips
on Jan 15, 2016 at 10:50:45 pm
Canon C300 records an MXF wrapped longGOP MPEG format that comes in three data rates:
25 Mbps (1440x1080) referred to as "thins raster" in Media Composer
35 Mbps (1280x720 and 1920x1080)
50 Mbps (1280x720 and 1920x1080)
Frame rates: 23.99p, 25p, 25i, 20.97p, 19,97i, 50p, 59.94p
8 bit video
4:2:0 in 25 and 25 Mbps modes
4:2:2 in 50 Mbps mode
MPEG2
Long GOP
every 1 hour of middle quality (35Mbps) at 23.976 will be 16.43GB
Higher quality (50Mbps) will be 23.18GB
Michael
Zoe Westley
on Jan 16, 2016 at 10:45:10 am
Great thanks Michael, I dont know where i got H264 from. But that all sounds great.
thanks
Shane Ross
on Jan 15, 2016 at 10:51:07 pm
[Zoe Westley] "
I was under the impression that the Canon C300 creates H264. is it just the compression that is H264"
Nope. It's the "Canon XF format," that's an MPEG-2 variant...XDCAM.
http://www.bhphotovideo.com/c/product/839220-REG/Canon_5779B002_C300_Cinema...
[Zoe Westley] " if so that might be a problem as they are shooting on location and need to upload the rushes to me every night."
Might be. Are they compressing it to H.264 and sending it to you? How did you get H.264 into your noggin?
[Zoe Westley] "will the file sizes be massive? it looks like 43mins of shooting(1920x1080 4.2.2) will create approx 23GB off data. Does that sound about right? "
I don't have access to the raw media at this moment to verify that....I can later tonight, give me a few.
[Zoe Westley] " i've never had much luck with link to AMA and then consolidating. I find the AMA link too slow and sluggish - especially on an iMac"
Sluggish? It's only sluggish when you PLAY the footage. AMA linking is instantaneous...well, near instantaneous.
[Zoe Westley] "Please can you talk me through the process/options you use - it would be massively appreciated."
AMA link each card into a separate bin. Once populated (it takes seconds), I highlight all the footage, and in the CLIP menu choose CONSOLIDATE/TRANSCODE. I use the CONSOLIDATE option...set a target drive and let it rip. All that does is copy the media from the backup drive the masters are on to the MEDIA drive I use to edit with. It takes as long as a drag and drop copy would. And you can do it in the background if you have MC7 or higher. Then I take the .new clips and organize those. Pretty straighforward.
If I transcoded, I'd just use the TRANSCODE option and transcode to DNx145 or 175. This will take longer as it's converting the media, recompressing it. But in a near lossless way.
[Zoe Westley] "alternatively if i do a mix down at Video Mixdown to DNxHD 220 - would that be high enough quality?"
Uhm...yeah. That's a VERY high end, high data rate codec. A lot of people don't even go there because the data rate is much higher than the source. Given the source, DNx145 is a good option as well. You REALLY won't see any loss doing that.
Shane
Little Frog Post
Zoe Westley
on Jan 16, 2016 at 10:50:22 am
thanks Shane. i've just tested this avid AMA linking to some QTs I have, and they seem to play okay, and it doesn't seem sluggish,, so should be a good workflow. out of interest would i have to transcode, could i just AMA link and edit from there? thanks for the tip.
Sorry it was a long day yesterday i misread DNxHD 220, yes indeed that is super quality. Thank you. will do that.
Zoe
Zoe Westley
on Jan 16, 2016 at 10:52:07 am
i got the H264 because i was under the impression that they could set the camera to H264 or Mpeg video codecs. Looks like i am wrong. either way it seems like straight forward workflow
Zoe
Zoe Westley
on Jan 17, 2016 at 11:59:52 am
Hi Shane/Michael
I have one last question, there is a possibility that they will be shooting 2K now, and shipping a drive, not uploading, would the workflow be the same? ie: Link to Ama then Consolidate?
thanks
Zoe
Michael Phillips
on Jan 17, 2016 at 7:41:20 pm
Workflow will be the same. What is the final delivery of the music video, 1920x1080? If so, then the 2K will be scaled or you will have the ability to so very slight re-composition of the image - but only ever so slight.
Michael
Zoe Westley
on Jan 17, 2016 at 9:42:37 pm
Thanks Michael, delivery is meant to be 1920x1080. However if they do shoot at 2K they may change their mind about delivery and opt for 2K -not sure yet. I would still need to edit at 1:1 as we have no time to conform on this project
Zoe
Michael Phillips
on Jan 17, 2016 at 11:27:09 pm
Other than a DCP there is not a whole lot of reason for 2K acquisition - you can scale it to 1080, but there is not enough of resolution difference to take advantage of supersampling or over-sampling as described in this blog: http://endcrawl.com/blog/2048x1152-is-a-total-crock/
And the fact that Media Composer's resize algorithm is OK, but not great to start with.
But workflow wise, it is the same - as what your 1920x1080 would be.
Michael
Shane Ross
on Jan 18, 2016 at 12:30:16 am
The only 2K delivery really is DCP. 2K for 1080 doesn't allow for repositioning much either
Shane
Little Frog Post
Zoe Westley
on Jan 18, 2016 at 11:06:52 am
got it thanks.
when i select Video Mixdown, there isn't a DNxHD 220 option on this system, so i was going to choose DNxHD 185, would that be okay or should i select 1:1 MXF.
The rushes are arriving on drive tonight so i am just doing tests.
thanks os much
Michael Phillips
on Jan 18, 2016 at 2:34:26 pm
220 represents the data rate at 1080i/59.94 - so if you are at 23.976,24, or 24 it will be 175 or 180/185. The x represents 10 bit version. I don't think you will get much value out of 1:1 compared to 185 based on your sources and it will take up 4.5 times more storage.
Zoe Westley
on Jan 19, 2016 at 2:11:38 pm
Thanks Michael, so i have just found out that they have added another camera to the mix the Canon Fs7 - shot at 2K, but delivery is still just 1920x1080.
My question is, should i AMA link and Consolidate, like with the C300 footage?or should i treat this footage differently
thanks
Michael Phillips
on Jan 19, 2016 at 2:25:04 pm
I think you meant to say Sony Fs7 and not Canon?
Here is a link on Fs7 versus sC300 - It seems that the Sony is either HD or UHD 4K and does not shoot 2K - Either way, you will be AMA linking to the camera originals and doing a transcode. "IF" they are shooting 4K on the Sony, then you have lots of reframing potential. If you are on 8.x you can choose to transcode to DNxHR and keep original resoluton.
Will they be shooting LOG and you apply LUT or will you color correct original LOG images?
Michael
Zoe Westley
on Jan 19, 2016 at 2:50:08 pm
Hey Michael, they have just filmed everything and it sounds very chaotic - oh no - they have said the Fs7 was filmed at 2.7K and drone footage at 3K. sounds odd, but i'll see when it arrives later. Looks like a long night of transcoding etc.
So it looks like i should transcode to 185MXF - that looks like it would make most sense. would i need to select 'apply source transformations?
They said that they shot LOG without a Lut. we'll be going in to a proper grading suite for this one. So i'll export a 185MXF video mix down - as a same as source QT.
Zoe Westley
on Jan 19, 2016 at 2:56:51 pm
one last question i should have added, AMA Source Scaling Quality i was thinking of selecting full. but seeing as its 1920x1080 delivery would half (best quality) be better?
thanks
