dollar signs over clips?
Ludmil Kazakov
on Jan 13, 2016 at 6:21:05 pm
updated to 8.4.. and now there are dollar signs over clips.. any ideas why? i am still in trial mode
Michael Phillips
Re: dollar signs over clips?
on Jan 13, 2016 at 7:27:52 pm
Can you post a screenshot?
Michael
Ludmil Kazakov
on Jan 13, 2016 at 8:05:31 pm
here it is
Shane Ross
on Jan 13, 2016 at 8:21:38 pm
Those aren't dollar signs...those are NEW graphic indicators that there's something different about the clips. Before, all you'd get is a green dot, meaning "something about this clip is different." now, Avid tells you WHAT about the clip is different. S means SPATIAL, meaning that the clips are a different size than the project. Say 4K clips in a 1080p project, or SD clips in an HD project.
Shane
Little Frog Post
Michael Phillips
on Jan 13, 2016 at 8:32:31 pm
You can turn these off or on individually in timeline settings if you want under "show adapters." To elaborate, you can see up to three indicators:
1. C for color (A LUT has been applied to the source)
2. S for spacial (source raster does not match project or has FrameFlex)
3. T for temporal (frame rate does not match project rate)
Michael
Ludmil Kazakov
on Jan 13, 2016 at 9:46:57 pm
that makes sense.. thanks guys! yes this is 1080 footage in 2k project..
