ProRes HQ QT Export with 10 audio tracks
Sarah Bright
on Nov 20, 2015 at 4:54:51 pm
Hi all,
I've been asked to export a ProRes QT as with the following audio specs:
48khz, 24bit/16bit
A1&2: Full Stereo Mix
A3&4: Dialogue
A5&6: Narration
A7&8: Effects
A9&10: Music
I know how to do this from FCP and I'm sure I've done an 8 track export at some point from Avid but 10 is a head scratcher!!
Delivery Monday so if anyone can shed some light on this then that would be awesome!
Thanks in advance!
Jon Hensen
Re: ProRes HQ QT Export with 10 audio tracks
on Nov 20, 2015 at 11:37:32 pm
In the export interface navigate to the audio tab and select "DIRECT OUT".
This will export your sequence as it is configured.
The only catch for DIRECT OUT to work is that all of the footage needs to be uniform in the same codec. If you have mixed codecs but are happy with the resolution of each file, you can perform a video mixdown in order to allow the DIRECT OUT option to work.
Sarah Bright
on Nov 23, 2015 at 10:35:53 am
Hi, thanks for your reply but I've done a video mixdown to prores hq and direct out in the export settings is greyed out?
