Corrupted DNXHD file, need to repair!!
Ryan Northcott
on Nov 9, 2015 at 4:40:03 pm
Hey guys, first post here and it's a problem. I was filming over the weekend for our doc series on a C100 mk1 and Ninja Blade set to DNXHD 220x. Everything was going just fine until I brought the files over into Avid and they wouldn't link. Getting a 'corrupted file' error. So I open up the files in VLC, and lo and behold I am getting some very strange horizontal colour artifacts. Almost like a bad record head look on a tape, but very colourful and obviously a digital corruption. It just keeps getting worse and worse as the clip progresses as well.
I absolutely need this footage to work, has anyone seen anything like this or have any idea if it is repairable? The footage is indeed there (according to VLC), but I can't get it to actually play back on any of our NLE's.
Pic is attached, check it out.
Thank you
Robert Ober
Re: Corrupted DNXHD file, need to repair!!
on Nov 10, 2015 at 9:47:08 pm
Are the camera originals OK? Assuming you are working off of copies, I would open the camera originals in Resolve and see what they look like.
Hope you fix the issue,
Robert
Robert A. Ober
IT Consultant, Vidcaster, & Freelancer
http://www.infohou.com
Houston, TX
Ryan Northcott
on Nov 10, 2015 at 9:49:14 pm
Stupidly I did not record internally as everything seemed to be functioning fine. The C100 is crippled by such a low bitrate that we use DNxHD files from the Ninja pretty much exclusively.
