GOPRO workflow for Avid MC
Will Fiennes
on Oct 6, 2015 at 11:21:16 am
Hi all,
Looking for some Goro help.
In my experience Gopro and Avid can be a rocky road when doing conforms.
In the past I have witnessed workflows as such:
Rename Gopro MP4s using something like "A better Finder Renamer" so that every clip has a unique name
Wrap Mp4s to Quicktimes to make Avid a bit happier using VideoToolShed GoProToQT
AMA and Transcode to Dnx36
Relink at conform and transcode to DNX185x
The one point where I am coming stuck is the rewrap to MOV. I can perform this fine but it changes the time of day timecode. Although it would be pretty difficult to sync with our main cams anyway some indication of time of day would be good .
When I wrap I have two options.
Use file modified time for TC instead of 01 hour based or not
Either way the TC changes. Is there no way or wrapping and retaining the same Time of Day ??
W
Freelance Assistant Editor / Post Production Op / Learning to Shoot asap!!
raj singh
Re: GOPRO workflow for Avid MC
on Oct 6, 2015 at 1:45:01 pm
Why the re wrap? which version of MC are you using you can bring in the mp4 native and then transcode
Will Fiennes
on Oct 6, 2015 at 2:13:31 pm
My understanding is that Avid is a lot happier with MOV than MP4 with AMA and the Gopro codec. This may be a hangover of mine from the past when using MC v5 etc
Using 8.4.2 on OSX 10.10.3
I am just doing a transcode and relink test. Will report back but any thoughts appreciated
W
Shane Ross
on Oct 6, 2015 at 3:28:37 pm
Yeah...no need to re-wrap. Just AMA link and then transcode.
Shane
Little Frog Post
Will Fiennes
on Oct 6, 2015 at 3:49:58 pm
Lovely
Cheers for the help.
W
Will Fiennes
on Dec 14, 2015 at 3:04:56 pm
Update on this
MP4 Transcode works well and relinks in 99 % of circumstances to correct clips. however with a re-wrap to MOV, I am seeing transcode times cut in half. I guess the legacy of Avids MP4 dislike is still being felt
W
Richard Sanchez
on Dec 14, 2015 at 10:58:25 pm
I'd highly recommend you use MP4 to QT first. It will combine spanned clips and add timecode based on the time modified of the file. It's not as accurate as true TOD timecode, but it's something. Do that first, then AMA and transcode.
http://www.videotoolshed.com/product/66/mp4-to-quicktime/3
Richard Sanchez
Los Angeles, CA
"We are the facilitators of our own creative evolution." - Bill Hicks
