Split track Quick Time
dan crouch
on Sep 24, 2015 at 1:26:29 pm
Hi Guys,
Can anyone please tell me how rto make a split track QT in MC*?
Ty
Shane Ross
Re: Split track Quick Time
on Sep 24, 2015 at 3:53:41 pm
https://forums.creativecow.net/thread/45/897962
Shane
Little Frog Post
Richard Sanchez
on Sep 24, 2015 at 5:30:28 pm
Easiest way is to make sure you've mixdown your audio into the appropriate splits you want (or if you're using mix stems lay them in the track configuration you need). Export a QT Reference (Make sure you select the audio mixdown). The Quicktime Reference will create a discrete channel for each track. After that you can safe a self contained Quicktime in Quicktime Pro 7 or if you need to compress it, you can run it through compressor.
Richard Sanchez
Los Angeles, CA
"We are the facilitators of our own creative evolution." - Bill Hicks
dan crouch
on Sep 28, 2015 at 1:42:00 pm
Thanks for the post's guys.
I did a mixdown in the end and it worked fine.
Very much appreciated.
Dan.
